Sample-based synths are stale and rigid. Any sound effect in action
will noticeably quantize and alias the music. They are a hell an
earsore for life-wanting instruments such as synth pads and synth fx.
The tone of synth pads are generated on FM synths! No wonder pads
sound so crappy in samplers.
A *real* digital (not analog) FM/modelling synth is a dream! It should
be hard-coded and able to do its own processing and memory.
Well, yes, I agree. Your dream machine exists, btw. It's called the
Yamaha FS1R. It has 64 operators, each with its own independent
amplitude envelope. 32 of these operators can do sine, square or
sawtooth waveforms (and formant shape them, either statically or
dynamically). The other 32 can do pitched or unpitched noise (you can
go from a sinewave right out to white noise, depending on bandwidth
settings). (compare with the original DX7, which had only 6 operators
- so this is 10 DX7's in a box!)
It is four-part multi-timbral with three independent effects units and
a comprehensive range of filters. It can do formant synthesis. It
produces utterly beautiful sounds which respond to every nuance of
your playing.
Faced with such a beautiful piece of hardware, Yamaha marketing then
did their best to screw up, first with an inadequate manual, then,
panicking, they took it off the market after only a year or so, when,
understandably, buyers balked at the complexity of programming it
themselves. (it did not, originally, come with a PC-based programmer,
which didn't help).
At which point they became collector's items. I drove 300 miles to buy
mine second-hand. I will never ever sell it. It is, undoubtedly, the
deepest, most powerful hardware synth ever made. And not a single
sample anywhere in it (except, I guess, a sine wave).
I don't understand why Yammy don't bring them back now that FM is back
in vogue. With a better manual and more sample patches they really are
something else.
Anyway, see if you can get hold of one. I think it will answer your
prayers, but be warned; it is deep and complex.
(another, software-based, alternative is NI's FM7 but this lacks the
raw power of the FS1R, though in theory you could run multiple
instances on a sufficiently powerful PC).
