Shure SLX4 Receiver
Discussion in 'Radio and Wireless' started by Jayanth, Mar 5, 2021.
  1. Jayanth
    Jayanth
    Mar 5, 2021
    Hi ,
    I have 4 slx2 mic transmitter , however I don't any receiver. Also this SLX4 P4 frequency receivers are not available in india.
    Is there any solution by changing the Crystal of any other shure Receiver and make them work?
    Is it possible?
    Please support.
  2. Harald Kapp
    11,660
    2,696
    Even if possible (I don't know) it is likely to be illegal as the transmitter will be tested and licensed to the original frequency band only.
  3. Martaine2005
    Martaine2005
    3,555
    966
    May 12, 2015
    Not sure why you can’t buy online in India, perhaps 638-662MHz is illegal?.
    The receivers are fairly cheap second hand and readily available.
    You will also need the receiver to change frequency and pair the mics.
    But for testing purposes, you may be able to use a frequency scanner. My personal scanner skips those frequencies.
    Martin
Similar Threads
Loading...
