Shunt Resistance
Discussion in 'General Electronics Discussion' started by Saad Waheed Abbasi, Dec 12, 2016.
  1. Saad Waheed Abbasi
    Saad Waheed Abbasi
    Dec 12, 2016
    i am performing an experiment on opamp in procedure it says''
    Shunt R2 by a 10kΩ resistor
    Shunt to be added in series or to the ground.
  2. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    Neither series or to the ground.
    To shunt R2, connect the 10kΩ resistor across it i.e. between B and C so that the connection will now be somewhat less than 10kΩ.
    Resistors in parallel, add the conductances.
    1/100k + 1/10k = 1/?
    Saad Waheed Abbasi likes this.
  3. Saad Waheed Abbasi
    Saad Waheed Abbasi
    Dec 12, 2016
    Thank You
    ok you mean like this
    and what if have to shunt R1
  4. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    Yes, and to shunt (connect in parallel) R1 connect between B and ground.
