Shrouded banana jack with hex nut
Discussion in 'Electronic Components' started by Andre Majorel, Aug 15, 2012.
  1. Guest
    Pomona 72930 might do what you want. It has a hex nut:
    http://www.pomonaelectronics.com/pdf/d72930_002.pdf
    About $2.20 each from various US suppliers. They are available in
    various colors.
    I hope this helps!
    Standard disclaimers apply; I don't get money or other consideration
    from any companies mentioned.
    Matt Roberds
  2. Yes, that's what I'm looking for, except for the stud
    termination. They'll cost more than round nuts + tool in the
    long run, though. I'll keep looking. Thanks again.
  3. Guest
    Pomona 6387? It has a solder turret terminal.
    http://www.pomonaelectronics.com/pdf/d6387_101.pdf
    Otherwise, it might be possible to buy the jacks that take the strange
    nut, and replace the strange nut with a hex nut. At least for the
    Pomona parts, though, the strange nut seems to have a strange thread -
    one drawing of the jack implies that the major diameter of the threads
    is about 10.8 mm, which is *in between* M10 and M12 threads, and also
    *in between* US 3/8 inch and 7/16 inch threads.
    Matt Roberds
