An open circuit may cause the total power supply current to go up or down.
Why would an open circuit cause the total power supply
current to go up or down?
Does an
open circuit cause the Total power supply
Voltage to go up or down?
Does a
short circuit cause the total power supply
voltage to go up or down or stay the same?
Because from my experience , A short circuit only changes the total power supplys current either up or down and the voltage stays the same
When there is a short circuit somewhere on the board, all the voltage drops are in millivolts and the currents are in microamps or nanoamps
When the circuits are in normal operations, the voltage drops are in volts not millivolts and the current is in either milli-amps or microamps
For Open Circuits, There is no current flowing through them. But their is DC Voltage on both sides of the component with the same potential?
For Open Circuits, The current
kirchhoff's never made it clear as to make his current and voltage laws applied to open circuits and short circuits
Because Kirchhoffs KCL states that the total power supply currents will equal whatever the whole circuit is Drawing from it.
But Kirchhoff never explains what happens to his KCL and KVL laws when there is a Open circuit or short circuit
Yes, when you have a open circuit or short circuit somewhere in a circuit or network the KCL and KVL will have to equal the total power supply voltage and current
The KCL and KVL doesn't explain what a open circuit or short circuit does to the current or voltage LOOP because the open or short takes a percentage of the total power supply current.
0.) All the Currents and voltages should Equal the Total power supply current and voltage
1.) Each SHORT is different and will take from a range of 1% to 99% of the Total power supply current.
2.) A Short will change the circuits Drawing current value of normal operation.
3.) An Open Circuit will change the circuits current or voltage drawing value of normal operation right?
4.) An Open Circuit should draw LESS current from the power supply, So the Total powers supply current will be Lower it, will go down?
5.) A SHORT has no voltage drop across it, but has very high current
6.) The Component around the SHORT circuit will have Big or lower voltage drops compared to normal operation?
7.) A Open Circuit changes the voltage drops only in that faulty stage but doesn't affect the other stages or networks?
8.) An Open Circuit Has the same DC potential voltage on both side of the component?
