Short/open circuit detector in wall
Discussion in 'Sensors and Actuators' started by Junjie, May 10, 2018.
  1. Junjie
    Junjie
    May 9, 2018
    Hi..what sensor that can easily detect open and short circuit in walls at home except testers / multimeters .thank you
  2. bushtech
    bushtech
    1,013
    157
    Sep 13, 2016
    If there is a fault in a cable get an electrician to pull a new cable through. Detecting the fault is just extra cost and doesn't fix it.
    davenn likes this.
  3. MicroMe
    MicroMe
    21
    May 18, 2014
    For detecting a break in a free cable I short circuited the far end and connected an audio signal generator to the other. Then using my hifi amp with a open ended cable ran this along the cable listening to the signal. The loss of signal at the break was quite dramatic and located within mm's.
    For a power cable in a wall replacement as bushtech suggests is the best option as even if located how will it be repaired without lots of decorating. A big concern is how or why it got damaged.
  4. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    opens and shorts are rarely anywhere except at either end of the cable. If you have a problem, check at the outlet and at the fusebox. The chances of a short/open anywhere inbetween (unless there is a hidden junction box) are as good as zero.
    bushtech likes this.
  5. shrtrnd
    shrtrnd
    3,803
    507
    Jan 15, 2010
    I think it would help if you explained exactly what you mean.
    As noted in previous posts, is this for audio signals, power wiring, or something else.
    I'm curious about the 'open or short circuit in a wall' question.
    What kind of application are you talking about?
  6. BobK
    7,682
    1,688
    At least here in the US, multiple outlets are strung together from the fuse box. If one outlet is out, it could be an open at another outlet in the same string.
  7. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    I was asked to look at a friend's mother's house. The deep freeze in the garage was live (240V) and she was complaining of the shock when she opened the lid:). I tested it with my magic screwdriverand declined to touch the freezer.
    The poblem was that she had had the walls impregnated with silicone and the contractor had drilled the wall and managed to cut the earth wire and connect it to the live. A new cable was fitted.
    Have you been hanging pictures or fitting shelves?
    darren adcock likes this.
  8. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Same here - but the faults, if any, will be at the socket plates (not withstanding anyone drilling holes or putting screws in them).
    Our own installation safety instructions (UK) show the position of cable runs and it would be unusual for someone to drill or screw into a cable - basically avoid anywhere in a vertical line above the outlet and in a horizontal line between two adjacent sockets.
