Shift registers : no output ?
Discussion in 'Electronic Design' started by aalex, Aug 19, 2007.
  1. aalex
    aalex Guest
    Hi !
    I am trying to drive 16 LED using a microcontroller and two 74HC595N
    shift registers. It didn't get to control a single LED so far. When I
    upload the code, the LED become either HIGH or LOW, but I can't
    control them.
    Below is a pseudo-code of the actions executed by the microcontroller.
    Everything seems to wired correctly, but it still doesn't seem to
    work. I need to drive some LED with that. I tested the output with a
    multimeter, and every pin out stays at HIGH (5V). I wired everything
    like in this circuit : http://www.ucapps.de/mbhp/mbhp_doutx4.pdf The
    microcontroller receives the data well : I can verify it.
    Everything seems ok :
    * The "output enable" pin is active (LOW).
    * The "master reset" pin is inactive (HIGH).
    * I need to power LED that need 30mA : this could be an issue, but
    still, the multimeter tells me that there is no fluctuation in the
    output voltagee of every shift register in my circuit.
    Here is the pseudo-code :
    set the "storage register clock input" pin to LOW
    for each register's output pin from 0 to 15 do: (I use two shift
    registers)
    set the "serial data input" pin to some value
    set the "shift register clock input" pin to LOW
    set the"shift register clock input" pin to HIGH (this clock pin is
    low-to-high triggered)
    set the "storage register clock input" to HIGH (this clock pin is low-
    to-high triggered as well)
    Anything wrong with this algorithm ? Someone can point me to an error
    I might have committed.
    Thanks a lot !
    alexandre
  2. Hello Alexandre,
    The schematic and your code seems to be ok.
    Have you checked that your control signals have 0V/5V levels?
    Many modern microprocessors run with less than 5V today.
    The circuit wouldn't work with a high level of 3.3V for example.
    Best regards,
    Helmut
  3. John Fields
    John Fields Guest
    Your "set the "storage register clock input" pin to LOW" seems to
    be outside the loop, which means the register clock will never be
    reset after it's asserted the first time.
    If you want your outputs to change sequentially, your code should
    look something like this:
    load a counter with hex 10
    loop: set the "serial data input" pin to some value
    set the "storage register clock input" to LOW
    decrement the counter
    is the count > 0?
    if yes, goto loop
  4. John Fields
    John Fields Guest
    Alternatively, you could wire the shift clock and the register clock
    in parallel, in which case the outputs would change sequentially,
    but output would lag input by one clock.
    Your code would then look something like this:
    load a counter with hex 11
    is the count > 0?
    if yes, goto loop
  5. John B
    John B Guest
    You might be better doing it the way the data sheet shows:
    set the "shift register clock input" pin to LOW for each register's
  6. Steve
    Steve Guest
    Your pseudocode and schematic looks right - standard SPI kind of
    implementation. I assume that the line:
    is after the for-loop, which is correct.
    If you set the clock line low then high immediately, you could create a very
    narrow pulse if your processor is running at a high clock rate. Make sure
    you meet the minimum clock time for the HC595. Add long lines and parasitic
    capacitances, and you might not get a valid signal level, rise time or pulse
    width at the 595 SCK inputs.
    I have found 595's RCLK line to be susceptible to noise and false
    registering in several applications like this. Consequently, I usually put
    100-300 pf to ground on the RCLK line to squash noise pulses. It has proven
    effective at fixing erroneous outputs in several cases.
    If you haven't already done this, try slowing the whole clocking process
    down to the 100 Hz - 1kHz region, to see if things begin to operate
    correctly.
    When you say the "microprocessor receives the data well", do you mean you
    are reading back the previous message from the far end of the chain? If you
    get the right stuff back, then obviously the 595's accepted the bits
    correctly. That would point to a problem with RCLK transferring the stored
    data to the output pins.
    And I agree with Helmut's comment to assure your processor outputs are high
    enough for the HC595. I usually use HCT parts to get the lower input
    threshold with 3.3V processors, and I still usually add 5V pull-ups to be
    sure, as long as the processor outputs are 5V tolerant.
    Good luck,
    Steve
