rockrockmcrock
- Dec 19, 2011
- 41
- Joined
- Dec 19, 2011
- Messages
- 41
Hi gurus,
I'm trying to work out what happened to fry a schottky diode in a second hand battery I've been given.
The battery has a small PCB that includes a charging port, connection port (for connecting the battery to the equipment, and a diode for reverse polarity protection.
The pack would trickle charge at 70mA, the diode is rated at 400mA and has a capacity of 1100mAh.
If trickle charged through the port all current passes through the diode.
A jumper can be added to the connection port which bypasses (shorts out) the diode, this allows for battery cycling/conditioning.
I suspect the battery has been cycled at 1C (1100mA) with the jumper attached. The 400mA diode is still in the circuit but shorted. Would current still flow through the diode? and is this what blew it (it is really toasted!)?
I have to say I'm confused as I thought that if you short something out in a circuit the current works like water in pipes and it all takes the path of zero resistance (i.e. the short)
Thanks guys!
Thanks guys!
