Sharp VL-NZ100U tape will NOT eject....
Discussion in 'Electronic Repair' started by lasunshine, Mar 19, 2007.
  1. lasunshine
    lasunshine Guest
    Recently, I've put in a protected tape into the unit to watch and the
    tape compartment retracted as usual. When I turned on the VCR mode,
    it indicated that I need to eject the tape. When I try to eject the
    tape, it does not come up like it usually does. It makes an attempt
    (since I can hear the noise) when I open up the tape area, but the
    tape compartment will not eject the tape and it is stuck. The battery
    is fully charged and I also try to the procedure with the unit plug
    with the AC adaptor. Can anyone HELP????!!!!!?!?!? I want to
    attempt to fix this on my own if possible.
  2. b
    b Guest
    lasunshine ha escrito:
    My advice is: forget it. Even experienced techs often ahte working on
    these intricate devices. You will screw it up without the service
    manual and training. take it to a service centre.
    -b.
