Sharp TV blows fuse
Discussion in 'Electronic Repair' started by Randy, Nov 15, 2003.
  1. Randy
    Randy Guest
    I have a 25" Sharp TV that blows it's fuse. I found that the horizontal
    output SCR (part Q602 on the schematic) was shorted. I replaced that part
    and as soon as I hit the power button on the set it blew out the SCR and the
    fuse. So I'm assuming that something downstream is causing the SCR to short
    out. Does anyone have an idea what I should check for? The TV model #
    is25H-M60.
  2. John Del
    John Del Guest
    Subject: Sharp TV blows fuse
    Sharps use an SCR for the power supply regulator, and a standard bipolar for
    the Horiz Out. Which one is failing?
    John Del
    Wolcott, CT
    "I'm just trying to get into heaven, I'm not running for Jesus!"
    Homer Simpson
    (remove S for email reply)
