electroninja said:
Sam and NSM:
Changed zener w/5.1v-- monitor lights dimmed otherwise no
change--replaced new zener with old and lights returned to normal--dead
end there I quess.
Any recommendations on board repair--pull and check every
component?--caps before resistors? Replace LC first? Have only VOM for
test equip with diode/transistor settings?
Either the microprocessor or its firmware is broken, or something is
tellting it to power down, like the sensor. Can you trace the sensor input
to where it goes. Maybe check components associated with that circuit.
And, of course, the DC power supplies. However, without an oscilloscope,
you won't be able to catch a momentary fluctuation. But at least you
can test to your heart's content without worrying about the high voltage
and microwave dangers as long as the HV transformer primary is disconnected.
Unfortunately, this is the type of problem that will produce premature
baldness in even experience techs and engineers.
--- sam | Sci.Electronics.Repair FAQ Mirror:
http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents:
http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ:
http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites:
http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
