Sharp Microwave Fan not working
Discussion in 'Troubleshooting and Repair' started by Margaret, Sep 1, 2012.
  1. Margaret
    Margaret
    Sep 1, 2012
    My microwave's fan, a Sharp R-1471 model is not working. all other functions are ok. I am not very electronically knowledgeable. should I try to fix it myself? If i replace it, are all microwaves a standard size?
    thanks,
    Margaret
  2. KJ6EAD
    KJ6EAD
    1,114
    159
    Aug 13, 2011
    You probably should refer it to someone who is knowledgeable about the hazards of high voltage and microwaves. Although fans are one of the easiest parts to replace if they're available, there's the possibility that the fault lies with a relay or other control component. At least one vendor shows some parts for that model and no, they're not standardized industry wide.
    http://www.partstore.com/Model/Sharp/Sharp/R1471.aspx
  3. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    If the fan is stiff, it might only be necessary to clean and lubricate the bearings.
    The voltages in a microwave are exeedingly high and can be retained on a capacitor even when turned off. Great care needs to be taken.
  4. shrtrnd
    shrtrnd
    3,803
    507
    Jan 15, 2010
    As noted above, working inside a microwave is dangerous, even when turned-off and
    unplugged, because of capacitors inside retaining their voltage.
    No, microwave ovens come in all sizes. If you replace it, you need to measure the
    space you have available, to make sure the one you buy will fit in the space available.
    I wouldn't try to fix it if you have no electronics background. If you don't know anybody
    who does know how to work on a microwave oven, I'd just replace it. They're not all
    that expensive these days.
    Good luck with whatever you decide.
