I am probably over thinking this. A 5mm shaft requires a 5mm mounting hub or 6mm ?
K Koen Crawford Jul 25, 2016 7 Joined Jul 25, 2016 Messages 7 Jul 29, 2016 #1 I am probably over thinking this. A 5mm shaft requires a 5mm mounting hub or 6mm ?
B Bluejets Oct 5, 2014 6,901 Joined Oct 5, 2014 Messages 6,901 Jul 29, 2016 #2 May need a whatsit or thingamajig
duke37 Jan 9, 2011 5,364 Joined Jan 9, 2011 Messages 5,364 Jul 29, 2016 #3 Do you have the correct measurements? Be very careful of 1/4 inch (old, 6.35mm) and 6mm (new). You may have to drill out the doofer.
Sunnysky Jul 15, 2016 541 Joined Jul 15, 2016 Messages 541 Jul 30, 2016 #4 yes 6mm threaded panel fasteners are used with 5mm shafted pots
