SFP breakout to another SFP
StealthRT
Sep 4, 2010
146
Sep 4, 2010
146
Hey all I am just wondering before I do this if its possible to connect 2 SFP sockets to each other in order to bring in the fiber connection and then take it back out the same way?
So in the image above, Pin 1 would hook up to Pin 1 on the second SFP socket. Pin 2 would hook up to Pin 2 on the second SFP socket, etc etc...
I'm doing this so that I can bring in the SFP connection into a server case and then once inside the server case I need to hook it up to a motherboard inside there that has the SFP connection.
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
Are you attempting to tap into it or simply couple two strands together?
You know there are passive components that do this right?
There has to be a reason you chose two SFP devices instead of a simple coupler.
You should also review the pinout... https://en.wikipedia.org/wiki/Small_form-factor_pluggable_transceiver#Signals
You can't simply connect pins 1-1, 2-2, etc. This is true with *many* devices. The pins are not bi-directional. At the very least, you may need to swap the Rx, and Tx pins but even then, you may not get what you want to accomplish
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
To better illustrate what I am trying to accomplish:
Still looks to me like you only need a coupler.
Fiber arrives at the outside of the case, gets plugged into the exposed portion of a 'passive' coupler.
Internally, the hidden side of the coupler is connected to a smaller strand of fiber that goes to your board.
StealthRT
Sep 4, 2010
146
Sep 4, 2010
146
it's for my ftth Internet connection so I really don't know what type of fiber connector they use...
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
Try here first. https://en.wikipedia.org/wiki/Optical_fiber_connector#Types
Step one. Identify the connector in use. Step two, is finding a coupler for that type of connector.
Something that lets you connect a Male - to - Male for example.
Regardless, you want/need a passive coupler. Don't bother messing around with trying to DIY pair two SFP modules together unless you have time and money to burn. Heck, you could even ignore the coupler and find the reverse gender of the connector in use, and simply put a small 'pig-tail' or extension inside the case.
StealthRT
Sep 4, 2010
146
Sep 4, 2010
146
this is what the ONT fiber hook up looks like that I am wanting to use (green connector).
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
It looks like SC to me... but I mainly work with LC.
Next question I have is... why tap into it there?
Does the SFP module you currently have use the same connector? If not, you will need a small patch cord with a different connector on each end.
StealthRT
Sep 4, 2010
146
Sep 4, 2010
146
Isn't the SFP cage able to adopt to the needed connector? Be that ethernet, single mode cable or multi-mode cable?
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
I was asking if the SFP module you *had* used a specific connector. You can buy them with various connectors.
In any case, you may need to do some research to determine what kind of fiber is in use. I think it would most likely be single-mode. Hopefully there is not a vendor specific SFP on the other end of that fiber.
StealthRT
Sep 4, 2010
146
Sep 4, 2010
146
I don't have a module.
and I can confirm that it is a single mode xable that comes to the house.
