M
Mike Edwards
Hello,
I am designing a circuit that must be able to rapidly select between two
precision voltage sources, but I am having trouble reaching an acceptable
compromise between precision and settling time. My requirements are as
follows:
- able to select the output of one of two steady-state DACs with
12-bit resolution
- output must settle to 0.02% within 200 ns
- input voltages may swing +-2.5v
- when selecting between two identical input voltages, the output of
the switch must differ by less than 1 LSB (~1mV)
To meet the first and last requirement, I need a dual analog switch whose
on-resistance is closely matched between channels. This, coupled with the
bipolar requirement, makes it difficult to meet the settling time
requirement. As far as I can tell, settling time is not very well defined in
analog switch datasheets, and I have little understanding of the variables
that affect it. The switch I initially selected, the ADG623, seems to meet
all my requirements. AD claims that it will turn on in 75ns, but after
prototyping and testing the circuit, I find that "turning on" does not mean
"settling to 0.02%". I get a nearly immediate charge injection spike,
followed by about 350ns of settling.
Does anyone know of any faster switches that will meet my needs, things I
may be doing wrong that could cause this to be so slow, any alternate
solutions that could work, or any reasons why this just isn't going to work?
by the way, the drains of the switches are tied together and fed into an
OPA681 (2pC||100k) in non-inverting configuration. The DACs are buffered by
OPA2227s, which are fed to the sources of the switches.
Thanks in advance.
follows:
12-bit resolution
Thanks in advance.
