P
Paul
I was able to get this set running by replacing a shorted diode in the
main bridge. It works fine now, except that the Vert height seems
slightly off. Looking at a service manual for a similar model, I
would expect to be able to adjust the height using the remote in
service mode. I took the remote apart and added a service jumper as
indicated on the PWB. I eventually pressed the correct button, or
sequence, to get the set into service mode, but could not find V-Size
adjustment. How is V-size adjusted on this model?
Paul
Paul
