Series resistor
Discussion in 'Electronic Design' started by eeh, May 18, 2005.
  1. eeh
    eeh Guest
    Recently I have a DSP filter project. From the DSP evaluation module
    circuit I found that for almost all digital outputs there are 33 ohm
    resistors connecting in series before to the target pin. I wonder if it
    is necessary as it would spend much PCB space in my custom board.
    Thanks!
  2. Robert Baer
    Robert Baer Guest
    Acts as a series termination, to "kill" reflections on the driven line.
    You obviously need some trace length to go from one IC to another; an
    0402 size chip will take no more space...
  3. eeh
    eeh Guest
    Thanks!
