Series/Parallel of 10 resistors question
Discussion in 'Electronic Design' started by John S, Oct 19, 2011.
  1. John S
    John S Guest
    I have 10 resistors of 18 ohms/25 watts each. I will use them for a load
    bank I am building.
    In trying to achieve flexibility, I began asking myself what maximum
    number of different resistances are possible with any combination of
    them. It is obvious that two in parallel is 9 ohms, three in parallel is
    6 ohms, etc, down to 1.8 ohms. It is also obvious that two in series is
    36 ohms, three is 54 ohms, etc up to 180 ohms.
    Then I began thinking of combinations of series/parallel like two in
    series (or parallel) with one in parallel (or series), and so on.
    I think you get my drift. My brain too old and out of practice now to
    set up the problem and I was never good at that Binomial Theorem thing
    to begin with. Can somebody enlighten me?
    Many thanks,
    John S
  2. TTman
    TTman Guest
    I'm too old too. Go to bed and think about it... guaranteed to keep you
    awake all night :)
  3. Martin Brown
    Martin Brown Guest
    And some of the more asymmetric combination networks will leave
    individual resistors under rather more stress than the rest. The OP
    would do well to bootstrap up from 2,3,4 by hand until he gets bored.
    Given N identical 2 port devices and a pair of nodes to connect using
    some or all of them how many distinct network paths are possible? (gives
    an upper bound)
    A more sensible approach would be to decide what load(s) and power
    ratings you actually require the unit to provide.
  4. John S
    John S Guest
    In retrospect, I probably should not have mentioned the wattage rating
    as that is not the burning question. The wattage can be adjusted so as
    not to exceed the wattage rating of any one resistor. I think I can
    calculate the greatest wattage dissipated by any one resistor for a
    given configuration. But, I need to have the configuration.
    The question of resistance remains. And I am still too old to do this alone.
    Thanks.
  5. John S
    John S Guest
    I don't grok bootstrapping resistors.
    Okay, please tell me. This may be what I am seeking.
  6. Hi John.
    This is an interesting problem, my solution would be based on the principal how
    you calculate the resistance of a circuit:
    - If two resistors R_1, R_2 are in series you replace them with a new resistor
    R_n1,2 with the value R_1+R_2
    - If two resistors are in parallel you replace them with a new resitor with the
    value (R1+R2)/(R1*R2)
    With these two simple rules we can analyze all resitor circuits. So we can also
    apply these rules "in reverse":
    If we have a circuit with n resistors we can replace any of those with either a
    parallel or a serial two-resistor-subcircuit. This gives as 2n new circuits (of
    which some can be equivalent to each other!). If we have only 1 resistor we can
    build exactly 1 circuit. So the formula for the number of circuits in
    dependence on the number of available resistors is:
    Circuits(1 Resistor) -> 1
    Circuits(n + 1 Resistors) -> R(n) + 2n
    If we solve this we get
    R(n) = n^2 - n + 1
    Now, since in your case all of the resistors have the same value, the real
    number of "different" circuits will be lower. Unfortunately I can not come up
    with a simple solution to this. So if you want to know, just write a program
    that starts with one resistor and uses the "expansion rules" described above
    until n resistors are used up and then backtracks.
    Since the number of states is qudratic this should give you an answer in
    seconds for small resistor numbers (<1000).
    Regards,
    Timo
    PS: I am a computer scientist, not an electronics engineer, so sorry if i got
    the resistor formulas wrong - that's just what i remember from highschool.
  7. Hi John.
    Circuits(n + 1 Resistors) -> Circuits(n) + 2n
    Circuits(n) = n^2 - n + 1
    Regards,
    Timo
  8. John S
    John S Guest
    Thank you, Timo. That may be a good start to get to my answer.
    Cheers,
    John S
  9. John S
    John S Guest
    So, you're saying my ancient mind is up to the task? Although I doubt
    you are qualified to judge that, I thank you, Tim.
    I did list some of the possibilities on paper:
    Two resistors have only two possibilities.
    Three resistors have four possibilities.
    Four resistors have eight possibilities.
    Then my brain broke. If the trend continues, would ten resistors have
    512 possibilities?
    I pass the ball to you, Tim.
    John S
  10. Mm... why?
    With two resistors you can build those three circuits:
    ---R----R---
    ----R----
    ----R----
    -----R------
  11. Guest
    I get three:
    Parallel
    Series
    Single (one shorted)
    Four, if you count two shorted (zero ohms)
    Five, if you count no-connects.
  12. Guest
    If this was the 1960s, and I had a bag of good weed, and had a 20 year
    old brain again, I bet I'd figure out the answer after smoking that
    bag of weed, and even tell you the meaning of life based on
    resistance, tolerance, and power.
    As soon as I figure out how to go back to the 1960's, regain my 20
    year old brain, and find a bag of really good weed, I'll give you the
    answer.
    Until then, I can honestly tell you the answer is somewhere between
    zero and infinite, and I know that is 100% correct and accurate, based
    on my PHD.
    You can view my PHD here: http://tinyurl.com/3cxkx75
  13. Martin Brown
    Martin Brown Guest
    ROFL. I had not intended a double meaning. Perhaps I should have said by
    induction starting from one resistor and working up.
    I think it might be slightly more obvious to cast the problem as using
    precisely M resistors how many choices are possible. Unfortunately
    determining which of them have distinct values is somewhat harder.
    M p(M) Values
    1 1 R
    2 2 2R, R/2
    3 4 3R, 3R/2, 2R/3, R/3
    4 8 4R, 5R/2, 5R/3, 4R/3, 3R/4, 3R/5, 2R/5, R/4
    You can derive the next line from the previous by adding an R in series
    or in parallel connected to one external node and every other internal
    node. There might be some others come out of the woodwork for larger N.
    2^10 is still a bit tedious though it would only take a few seconds to
    compute in any of the algebra packages or in a spreadsheet.
    And you should think really carefully about 9R||R load capacity.
  14. John S
    John S Guest
    Because the single R falls into the category of the number of ways of
    connecting one resistor (one way).
  15. John S
    John S Guest
    Your last two possibilities fall outside the scope of the question since
    they require no load bank at all.
  16. Guest
    Maybe, depending on your definition of "load bank". That's why I separated
    them. Specification of the problem, matter.
  17. John S
    John S Guest
    I came up with the same p(M) for M -> 1 to 4. I wonder if the p(M)
    sequence continues in the same fashion up to M = 10. If so, then p(M)
    would be 512 for M = 10. Also, wouldn't that mean that the total number
    if ways would be 512 + the sum of all the ways less than ten?
    So, would it be 2^9 + 2^8 + 2^7 +....2^1 + 2^0 = 2^10 ??
    If so, then the total number of possibilities would be 1024.
    I have. I will limit total power to 25W regardless of the configuration.
  18. John S
    John S Guest
  19. ehsjr
    ehsjr Guest
    There are 55 different value combinations with 10 equal value R's, not
    including shorted or open resistors. 9 possible purely parallel, and 9
    possible purely series. Then, the combination of N series with P
    parallel, where P+N < 11, and P>1. Note that P must be equal to at
    least 2, else it doesn't represent a parallel configuration and yields
    unwanted duplicates. For example, 8 in series added to P in parallel
    where P = 1 would be the same as 9 in series.
    It's easier to program than to figure out.
    Ed
  20. Martin Brown
    Martin Brown Guest
    That seems a bit silly. You could easily choose to use only those
    configurations that will handle close to maximum power and end up with
    something a lot more useful and a heck of a lot easier to build.
    eg. 1R = 3 x R||R||R (gets you 9x25W of dissipation)
    It is also incorrect. The parallel resistor can go to any node in the
    chain of series resistors and different numbers of resistors already in
    series can be placed in parallel. I couldn't convince myself that the
    construction I suggested above would get every possible network but
    according to Wolfram MathWorld my p(m) = 2^(m-1) is complete.
    http://mathworld.wolfram.com/ResistorNetwork.html
    (they do it for 1 ohm resistors)
