Does anyone know where i could get a serial to parallel convertor to
run 16x2 LCD from serial bit stream?
Kris
http://www.seetron.com/slcds.htm
Alternately, you could do it yourself. You could run the lcd in 4 bit mode and
use a 74H595 serial to parallel converter, and just use the D4-D7, Enable
and Register Select pins. You will then have two extra outputs on the '595
to use for turning the backlight on/off, a relay, or something else.
Or if you want to use I2C, use a PCF8574, I2C to parallel converter.
Regards
David
