Serial Stringing Resistors ??
Discussion in 'General Electronics Discussion' started by Raul, Oct 24, 2012.
  1. Raul
    Raul
    33
    Sep 25, 2012
    When stringing different rated resistors to get more resistance (for an LED array):
    Does it matter what order they are in; and if it does; does it matter what order they are in depending on whether they are the positive or negative lead from the PS?
    My instinct says put the large resister closest to the power supply positive lead and the smaller one after that. But my instincts are not terribly well informed.
  2. MrEE
    MrEE
    84
    Apr 13, 2012
    No it doesn't matter. The same current flows through anything connected in series.
  3. shrtrnd
    shrtrnd
    3,826
    527
    Jan 15, 2010
    Yeah, but I wonder about your statement that you want to put the large resistor closest
    to the power supply.
    Like MrEE said, the current will be the same through the series circuit.
    Make sure, if you're using different sized resistors, that the small ones are able to
    HANDLE that series current (wattage-wise).
  4. Raul
    Raul
    33
    Sep 25, 2012
    The watt load of my LEDS won't overwhelm the individual resistors I have. I'm just trying to avoid paying for shipping on a dollar's worth of resistors, so I'm playing with combining them to get a resistance value at or a little above what I need.
  5. MrEE
    MrEE
    84
    Apr 13, 2012
    Naturally, each resistor should handle the power (given by P=RI^2) .This shows that in series connection, the largest valued resistors will dissipate the most power. When selecting resistors I'd actually use a higher rating than the actual dissipated power (double or even higher). You never know what is the ambient temperature around the resistor... Again, as far as placement, it doesn't matter where you place them.
