M
michael
Hello there,
I am working on a FPGA project that requires to interface the FPGA with
an array of serial 12bit DAC. I can not use parallel 12bit DAC simply
because I don't have enough pin counts on that FPGA (360 pins are
needed if use parallel DAC). So I plan to write a synchronized serial
interface (clk, data, sync) to pump the data out as soon as the 12bit
data is generated inside FPGA. I image that I probably need a shift
register, PLL ( generate clocks for both shift register and the DACs),
a bit counter to signal the end of transmit? Does anyone have the
experience to do this? Please help.
Mike
Mike
