Serial eeprom programmer
Discussion in 'Microcontrollers, Programming and IoT' started by markm6164, May 5, 2013.
  1. markm6164
    markm6164
    118
    Jan 22, 2012
    I use a serial programmer that uses a DB25 parrallel port. Laptops no longer use these so I was looking for a solution. Is there some sort of adaptor to convert DB25 to USB?
    Regards
    mark
  2. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Yes, there are adapters, but I have never found any of the converters all that reliable overall, if they even work at all... The converters are generally designed to make a 'printer' work, not do a full proper adaptation that a lot of non-printer hardware requires...
    If you insist on using the old programer, I suggest keeping a legacy computer around, or else get a new programer...
  3. gregfox
    gregfox
    149
    3
    Mar 25, 2013
