Serial DAC
jamie1989
Apr 5, 2017
7
Apr 5, 2017
7
Hi, I need to control a DAC from a microcontroller which will inturn drive an amplifier, i'm going to make the DAC side of the circuit first without the controller and test it with an arduino, just needing to know if the attached circuit looks up to scratch and whether there's anything I could include to increase reliability etc?
DAC
http://www.analog.com/media/en/technical-documentation/data-sheets/AD5040_5060.pdf
OpAmp
OP295AZ/883
  • Schematic Prints3.pdf
Harald Kapp
13,742
13,742
Do you want to test our diligence? ;)
The conection of R2 to the '+' input of the opamp is wrong. It needs to go to the '-' input, see datasheet figure 51.
Although the datasheet shows +5V used as reference you should be aware that any noise on the 5V supply or any inaccuracy of this supply will have a direct effect on the output signal of the DAC. For precision operation I recommend using a precision reference, e.g. REF02 or any other similar product. Note that this will require an input voltage to the reference in excess of 5V.
jamie1989
Apr 5, 2017
7
Apr 5, 2017
7
Ha, you keep on volunteering! Thanks of the help again, always best to get a second opinion especially when mistakes can be made that easy!
Excellent stuff, I'll include it.
