Serial communication between 2 PIC16F877 via I2C or SPI
Discussion in 'General Electronics' started by [email protected], Feb 9, 2004.
  1. Hello out there...
    I would like to implement a evry simple serial communicaton between 2
    or n Microchip PIC controllers via I2C or SPI. There is no speed
    problem. I would like to use the controllers for a simple testing
    system.
    Does anybody have an example source code or an explantion how to do
    it. I already have some applications programmed with other PICs but
    now I need to have a serial data excanche - bi-directional.
    Thank you for helping me!
    Best regards
    Hans
  2. ChronoFish
    ChronoFish Guest
    You might be better off asking this in alt.microcontrollers and alt.microcontrollers.8bit
    There is also some example code on the c2c.com website. http://www.emicros.com/pic1.htm might help as well.
    Myke Predko's book - "Programming and Customizing the PIC Microcontroller", 1998 pp315-326 has several routines for 3-wire, I2C, and
    interrupt driven serial receiver/transmitter. The book comes with a disk with the code on it. You may also be able to find the
    code on the web.
    He happens to have a chapter on serial comm online at http://www.myke.com/pdfs/0071361723_Ch06.pdf or just http://www.myke.com for
    all the info.
    Hope this helps,
    CF
