sequential logic level indicator with D flip flops
Discussion in 'Electronics Homework Help' started by george2525, Mar 8, 2015.
  1. george2525
    george2525
    165
    Jan 30, 2015
    Hello.
    Ive been asked to do this realy simple idea using D type flip flops
    a single input is to light up 3 LED's in sequence - 000 / 100 / 110 / 111 and then if any additional highs are inputted - remain at 111 until a low is input, following which it will go backwards from 111 to 110 etc...
    im aware this is pretty basic but im quite stuck. I am thinking a shift register of some kind that can go right and left?
    the spec is that I use D type flip flops and that there is only one input (and a clock)
    If anyone has a min to throw me a few bones id realy appreciate it!
  2. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    So the problem is to design a state machine that could be described as an up/down Johnson counter with a truncated ring. Start the sequential analysis with a next-state table where the next-state of Q1,Q2,Q3 is determined by the previous-state of Q1,Q2,Q3 & INPUT. Then recognize that the next state is controlled by D1,D2,D3. Create truth tables for D1 & D2 & D3 from the Q1 & Q2 & Q3 & INPUT signals, and minimize the logic with a Karnaugh map for each D. Note that each D does not depend on every Q. -- That is the process for becoming unstuck in logic design.
