Sentrol Door Alarm
Discussion in 'Security Alarms' started by dlloyd9999, Jan 5, 2005.
  1. dlloyd9999
    dlloyd9999 Guest
    Hi all:
    I have an interesting problem - I got a new door installed, and they carted
    away the old one with the sentrol "stuck on" part - leaving the screwed-in
    sensor part hanging from the jam. I need to get the darn thing fixed as I am
    tired of overriding that particular sensor. So - where can I go to buy a new
    sticky part in Ottawa, Canada? Failing that, what can I use to spoof it to
    think it is closed even though the other half of the sensor is gone to the
    dump!
    Doug
  2. R.H.Campbell
    R.H.Campbell Guest
    From your description, it is a bit difficult to appreciate exactly what kind
    of contact is on your door. But give me a call at 798-3434 if you wish, and
    I might be able to help you out...I've got buckets of scrap and semi-scrap
    parts accumulated from years of being in the business.
    R.H.Campbell
    Home Security Metal Products
    Ottawa, Ontario, Canada
    www.homemetal.com
    www.flickr.com/photos/tourman
  3. G. Morgan
    G. Morgan Guest
    Subject: Sentrol Door Alarm
    Newsgroup: alt.security.alarms
    It's just a magnet.
    http://www.radioshack.com/category.asp?catalog_name=CTLG&category_name=CTLG_002_002_000_000&Page=2
  4. R.H.Campbell
    R.H.Campbell Guest
    This gentleman called me directly and I'll be fixing him up. Sounds like he
    needs a bit more than just a new switch for his older version non monitored
    system....
    RHC
    You can just,,,securely tape a magnet (any old magnet) to the dangling
    switch until you fix it properly. That will keep the switch closed, and the
    zone 'ready'.
    You'll have to put the switch (the dangling think) back into the door frame
    if it's a recessed switch, or glue or fasten it security to the frame its a
    surface mount switch. Then find a matching magnet to fix the problem
    permanently.
    | Hi all:
    carted
    screwed-in
    am
    new
    | dump!
    | Thanks
    | Doug
  5. Jim
    Jim Guest
    Uhhhh ........... Years?
    That would be about ............. ummmm aaahhhh ummmmm ..... about Six?
    Looks as if you may have caught a little of the " Bass innuendo virus"
  6. Jim
    Jim Guest
  7. dlloyd9999
    dlloyd9999 Guest
    Hi Everyone:
    Thanks for the assistance. The magnet suggestion did not work - I tried
    fridge magnets, office magnets, and a rare earth magnet, all with no joy.
    Mr. Campbell had a suggestion for me which worked quite well in the short
    term, and the monitoring company reports no problems as well.
    I appreciated all your suggestions, and thank you all!
    Doug
