Sensor signal frequency counter in arduino
Discussion in 'Microcontrollers, Programming and IoT' started by ram, Apr 17, 2014.
  1. ram
    ram
    Feb 7, 2010
    I used IR as my sensor and my task is depends on my IR sensors number of signals with in 1 min my output ill vary...
    ex: if IR signal is 1 my output 1 ill execute if IR signal is 2 my output 2 ill execute....
    i did this task by the help of loops without using counters & timers of controller... my question s how to use counters&timers for this task.......
  2. Harald Kapp
    11,292
    2,585
    Welcome to our forum, ram.
    One way of using counters and timers is like this (Pseudocode, you'll have to write the correct code for teh arduino yourself):
    Initialise a counter to increment by 1 for each signal from the IR sensor (e.g. trigger counter on rising edge of the signal).
    Set the counter to 0
    Initialise timer for 1 minute interval
    Set up an interrupt routine that will be triggered by the timer after the 1 minute count-down.
    Start the timer
    Go to main routine - counting and setting the port pins will be handled by the timer interrupt roputine, see below.
    This is what the timer interrupt routine does:
    Timer_interrupt()
    read counter and activate the port pin corresponding to the value of the counter (you should include some checks to avoid e.g. illegal values).
    reset counter to 0
    reset timer to initial value (so it will again count down 1 minute)
    end_of_interrupt
    Regards,
    Harald
