Sen. Harry Reid, NV: Wildfires caused by global warming
Discussion in 'Electronic Design' started by Jim Thompson, Oct 24, 2007.
  1. Jim Thompson
    Jim Thompson Guest
  2. Tim Wescott
    Tim Wescott Guest
    So? "Reid is a witless opportunist", i.e. he's a successful politician.
    Whycome that blog didn't have all the stupid things that Republicans do
    and say, eh? Maybe it's because the blogger is an opportunist, possibly
    witless, too?
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Do you need to implement control loops in software?
    "Applied Control Theory for Embedded Systems" gives you just what it says.
    See details at http://www.wescottdesign.com/actfes/actfes.html
  3. Don Bowey
    Don Bowey Guest
    Hmmmm!
  4. Eeyore
    Eeyore Guest
    Hilarious coming from Reagan of all people. To give credit where it's due
    however, Reagan didn't do too much harm.
    Politicians of ALL persuasions are unreliable. It's not unique to any variety.
    Graham
  5. flipper
    flipper Guest
    It's sad when someone defends duplicitous stupidity by claming
    everyone else does it but it's even sadder when it's called the
    'definition' of 'successful'.
    And then there's the more obvious possibility that a blog written on
    Tuesday, October 23, 2007 is about stupid things said on Tuesday,
    October 23, 2007.
  6. flipper
    flipper Guest
  7. Guest
    Right wing politicians are against what they call socialised medicine
    - and to the extent that they succeed in cutting back on health care
    for the indigent, they damage public health.
    http://content.healthaffairs.org/cgi/reprint/21/6/31.pdf
    Reagan's administration cut back pulbic health expenditure by 25%, and
    managed to reverse the steady improvement in U.S. public health for
    the first time in around 100 years. US public health statisitcs didn't
    go all that far backwards during his administration, but they did get
    worse.
  8. James Arthur
    James Arthur Guest
    So far, ALL the fires are manmade: Malibu (the Canyon fire) and Agua
    Dulce from downed power lines, and the Rancho Santiago fire was set
    (confirmed).
    Real-time aerial photos of the Magic / Stevenson Ranch fire--as it
    started--showed a suspicious black circle directly adjacent to the
    dirt service(?) road immediately west of Westridge Parkway, here:
    http://maps.google.com/maps/ms?ie=U...&ll=33.651208,-118.146973&spn=2.199313,4.4055
    There being no fire anywhere near the vicinity at the time, I expect
    that one will prove to be arson as well, and suspect that cause for
    the Arrowhead and Running Springs fires too.
    Time will tell.
    James Arthur
  9. Jim Thompson
    Jim Thompson Guest
    Yep. There's even some (unconfirmed) rumors opining that Islamic
    terrorists took the opportunity to join in. We'll have to wait and
    see if they claim any responsibility... which typically is their
    style.
    ...Jim Thompson
  10. Jim Thompson
    Jim Thompson Guest
    It's just now come over the radio that the FBI has entered the scenes
    investigating arson.
    ...Jim Thompson
  11. John Larkin
    John Larkin Guest
    Global warming makes people crazy, so they start fires.
    John
  12. Jim Thompson
    Jim Thompson Guest
    Yep. Sad isn't it ?:)
    ...Jim Thompson
    | James E.Thompson, P.E. | mens |
    | Analog Innovations, Inc. | et |
    | Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
    | Phoenix, Arizona Voice:(480)460-2350 | |
    | E-mail Address at Website Fax:(480)460-2142 | Brass Rat |
    | http://www.analog-innovations.com | 1962 |
    "It isn't that democrats are ignorant. Far from it... it's just that
    they know so much that just isn't so" -Ronald Reagan
  13. John Larkin
    John Larkin Guest
    It's 72F in San Francisco. I can't stand it. I think I'll set
    something on fire, a nice salmon steak, maybe.
    Speaking of heat, has anybody ever heatsinked an SO-8 opamp from the
    top side? Seems like some decent theta reduction might happen if we
    epoxy a heatsink to the top. We're running a National LM7372 power-pad
    part at about 70C, and it drops to about 60 when we push a big steel
    machine bolt head against the top, with some silicone goop. Looks
    promising.
    So we need a pagoda-type heatsink with a flat, thick bottom.
    John
  14. James Arthur
    James Arthur Guest
    Hmm--that link didn't zoom in on Westridge Parkway as I expected.
    This is it:
    The fire started off the north end, where Westridge Pkwy dead-ends.
    The latest update on the LA Times interactive Google map (previously
    linked) says it was accidentally started by welders. That may be
    true, but there sure weren't any welders in the vicinity when I first
    saw it, tiny, and within roughly 5 minutes of its starting.
    Maybe 'global warming' affected their judgement, then 'local warming'
    sent 'em packing?
    Cheers,
    James
  15. James Arthur
    James Arthur Guest
    I doubt it's 'Sama's boys. It's possible, but they're kind of busy
    ducking just now.
    Besides, they're pathetic--there's a lot of stuff they could do if
    they had the moxie. The amazing thing is that we let them provoke us
    so.
    Cheers,
    James Arthur
  16. James Arthur
    James Arthur Guest
    One of the semi-houses is offering top-and-bottom thermal paths...
    Ah, here it is, Vishay's PolarPAK MOSFETs: http://www.vishay.com/mosfets/polarpack-list/
    3.4deg C/W, and 1.2 deg C/W through the top. (http://www.vishay.com/
    docs/74422/sie830df.pdf)
    Cheers,
    James
  17. James Arthur
    James Arthur Guest
  18. It's sad when someone defends duplicitous stupidity by claming
    'definition' of 'successful'.[/QUOTE]
    Successful at politics, much like success at thievery. If you go and
    steal someone's money, and get away with it, that sounds pretty
    damn succesful to me, for a politician or other thief.! ;-)
    Cheers!
    Rich
