Self-holding transistor (or anything else) needed!!!
Discussion in 'General Electronics Discussion' started by canavaroski90, May 16, 2012.
  1. canavaroski90
    canavaroski90
    May 16, 2012
    Hi all.
    You may know how to assamble a self-holding relay circuit. When you contact relay's bobbin's pins to the +5V and GND, the other 2 pins will shortcut. However I need this setup without using relay.
    I know thyristors can do this but I do not have any. So, I'm trying to assamble this setup by using thyrsor's equivalent circuit diagram. However ıt doesn't work. I don't know where is the problem. I've assambled the equivalent circuit and gave power to the base, system worked, but when I cut off the power from base my circuit stops working.
    Can anyone help me?
  2. (*steve*)
    25,267
    2,718
    What are you actually trying to do?
  3. canavaroski90
    canavaroski90
    May 16, 2012
    Thanks for help. :)
