D
D from BC
I've noticed that most smps have a common mode transformer in the line
filter section.
I looked at this spec sheet on:
http://www.tdk.co.jp/tefe02/e93_uf.pdf
as an example.
At the moment I'm clueless on selecting a CM xformer for my
application and I'm tempted to fudge the selection..
Can I go for the maximum inductance until it takes up too much space?
Maybe a rule of thumb exists...say 1/4 the size of the power magnetics
in the converter?
I know this is crappy..I probably should know my noise level, target a
CSA conducted EMI limit, get my attenuation and then pick a CM
xformer.
With a working sim of my smps, can I estimate the required CM xformer
specs in LTSpice?
Whats the general design procedure for selecting a CM xformer?
D from BC
filter section.
as an example.
in the converter?
xformer.
specs in LTSpice?
D from BC
