Selecting Mosfets for Lowest Power Dissipation
Discussion in 'Electronic Design' started by D from BC, Feb 11, 2007.
  1. D from BC
    D from BC Guest
    I'm currently trying to find an effective way to select a mosfet with
    the lowest power dissipation for the following circuit values:
    Id=2A
    Vd=270V
    f=100khz
    D=40%
    Mosfet Driver Specs
    Claims up to 2A peak gate drive
    Tf = Tf = 14nS with 1nF load
    Rdson is just a conduction loss.
    Gate capacitance is the main cause of switching loss due to slowing
    down driver rates. <<Not sure about that..
    Rdson and gate capacitance are inversely proportional for mosfets?
    <<Not sure about that too..
    If so...
    By finding the balance between Rdson and gate capacitance, I could get
    less total power dissipation.
    In that case...
    Is there a figure of merit...Maybe like Ciss/Rdson? I just go for the
    smallest number?
    I've been looking at the SPP21N50
    Rds(on) 0.19 ohms
    Ciss = 2400pF
    This mosfet has a great Rdson but I wonder if I could get less
    dissipation with more Rdson and less Ciss?
    What's a good selection procedure?
    I''m hoping for some hints while I google for answers.
    D from BC
  2. D from BC
    D from BC Guest
    I found this:
    Taken from
    http://www.maxim-ic.com/appnotes.cfm/appnote_number/1832
    "Once you have narrowed the choice to a specific generation of MOSFET
    based on cost (the cost of a MOSFET is very much a function of the
    specific generation to which it belongs), select the device within the
    generation that will minimize power dissipation. This is the device
    with equal resistive and switching losses. Using a smaller (faster)
    MOSFET increases resistive losses more than it decreases switching
    losses; a larger (low RDS(ON)) device increases switching losses more
    than it decreases resistive losses."
    Neat.....50 50 on the losses...
    Rough formula for switching loss:.
    Pdswitching = (Crss x Vin^2 x fsw x Iload) / Igate
    (Igate is the MOSFET gate-driver's sink/source current at the MOSFET's
    turn-on threshold (the Vgs of the gate-charge curve's flat portion).)
    How much does Crss vary among mosfets?
    What a PITA...I also have to estimate Igate..
    Once I solve for Pd then I can calculate the corresponding Rdson..
    Then I have 2 specs to pick a mosfet out of a table of mosfets.
    Am I on the right track?
    Shortcuts??
    Is there an app where I just fill in the blanks and it just spits out
    a part number? :)
    D from BC
  3. Henry Kiefer
    Henry Kiefer Guest
    Sounds not so bad. Generally spoken, newer devices have lower losses (=smaller chip inside).
    I use LTspice to run efficiency calcs. It's easy. Use digikey to find what is buyable.
    I don't understand how Mot comes to the 50:50 rule.
    - Henry
    www.ehydra.dyndns.info
    | I found this:
    | Taken from
    | Shortcuts??
    | a part number? :)
    | D from BC
  4. John Fields
    John Fields Guest
    Rds(on) and Ciss aren't related except that the longer it takes to
    charge and discharge the gate capacitance the longer it will take to
    turn the MOSFET on and off. That means that during the time the
    channel is in transition it'll be dissipating a lot more power than
    it will be for the same time when it's either on or off.
    Ciss doesn't dissipate any power in the MOSFET except in the ESR of
    the gate capacitance, but the driver has to source and sink the
    charge and discharge current, so there will be some power dissipated
    in the driver.
    So, what you want to do is get a MOSFET with the Rds(on) you
    need/can afford and the lowest Ciss you can find, then drive the
    gate as hard as you can so that the MOSFET will turn on and off
    quickly.
    Using a MOSFET driver will save you a lot of woe, and some good ones
    are at:
    http://www.micrel.com/page.do?page=product-info/mosfets.shtml
  5. D from BC
    D from BC Guest
    You mean do it like this?...
    Let's say I can waste 2watts...
    Then I solve for Rds(on).
    Then I look at all the mosfets with that Rds(on) and pick the one with
    the lowest gate charge.
    Then ram the gate with powerful mos drivers and hope that Vg can rise
    and fall fast enough to lower switching losses. (Slow operation =
    heat.)
    Hopefully the switching loss is not significant compared to the heat
    from Rds(on).
    What I'm looking into is:
    Given Id, Vd, Igate, freq, duty; does a power dissipation minima exist
    given a wide assortment of mosfet Rds(on) and gate charges? A sweet
    spot...
    D from BC
  6. D from BC
    D from BC Guest
    I know...The rule is strange..
    50% heat due to switching and 50% of heat due to Rds(on).
    It shouldn't matter what combo...2%, 98%....40% 60%...20%80%....
    I just want lowest mosfet heat. (Neglecting mosfet driver dissipation)
    I could create a table of Rds(on) and gate capacitances based on
    mosfets available at digikey.. Then run multiple simulations in
    LTspice to find the coolest mosfet..
    Something just seems wrong about this...
    D from BC
  7. Henry Kiefer
    Henry Kiefer Guest
    | On Sun, 11 Feb 2007 12:20:12 +0100, "Henry Kiefer"
    | >- Henry
    At least the rule must have a function of duty-cycle!
    - Henry
  8. D from BC
    D from BC Guest
    I recently found this at:
    http://pd.pennnet.com/display_artic...Switching-loss-in-switch-mode-power-supplies/
    "It's surprising to note that at higher switching frequencies, a
    MOSFET with higher on-resistance can actually improve SMPS efficiency.
    You must look beyond on-resistance to understand this behavior. "
    So...I'm thinking..
    Given a mosfet drivers trise and tfall, I just have to get a grasp on
    how to pick a mosfets Rdson and gate charge.
    D from BC
  9. John Fields
    John Fields Guest
    Where?
    In the MOSFET?
    In the driver?
    Total from the supply?
    OK, that'll get you the steady-state dissipation if you know the
    supply voltage and the current into the load.
    That's the trick!
    The faster you can turn that booger on and off the lower your
    switching losses will be, but you'll have to pay the piper in the
    driver.
    Sure, and there's nothing magic about finding it.
    If what you're concerned about is steady-state power dissipation in
    the MOSFET, get one with the lowest Rds(on) you can find.
    If what you're concerned about is switching losses, get the one with
    the smallest gate capacitance you can find and drive it with a
    voltage source.
    If what you want to do is to get the best of both worlds, then
    you'll have to do the legwork to find out who minimizes both WRT
    your application.
  10. D from BC
    D from BC Guest
    I've heard of SiC Mosfets with ridiculously low Rds(on) but I suspect
    it's not available yet..
    D from BC
  11. D from BC
    D from BC Guest
    Ooops... should have specified that 2watts wasteable ..in my example..
    That would be 2watts = drain|source dynamic heat + heat from Rdson.
    I'm assuming that mosfet heat is far from the driver heat and is
    negligible.
    (D=40%, f=100khz)
    I don't know yet if the legwork is worth doing.
    ... For all I know I could spend hours just to discover the math and
    compare dozens of mosfets to get that optimum Rdson/gate charge combo
    and only end up with a minor 10% improvement compared to just
    selecting the lowest tolerable Rdson.
    D from BC
  12. john jardine
    john jardine Guest
    I've never hit a sweet spot. I filter on voltage it can cope with, then
    current, then price, then buy a couple.
    10nF, 1nF who cares? those gate C's are really big. Bang 'em with gate
    driver chips. Only killer is operating frequency.
    God know why but I spent 2 hours last month with paper and calculator
    looking at switch losses on a design using a pair of 80A FETs. Bought the
    FETs and the calculated heatsink, built it, run fine. Within 5 minutes and
    for other reasons I'd changed the design to a higher Frequency and a
    different switching arrangement. Those 2 hours now lost for all time. Lesson
    learned was don't waste valuable time with the sums, just select on price
    and keep an eye on the spice.
  13. D from BC
    D from BC Guest
    Interesting...
    Are you saying that it's so complicated that hit and miss
    determination is the faster method. Just pick the essential mosfet
    specs and then compare in spice..
    Select on price...Eye on spice
    Nice electronic poetry... :)
    D from BC
  14. Gibbo
    Gibbo Guest
    If you look at the Rds losses and the gate capacitance losses you'll
    realise you can calculate the whole lot dead easily. Then as you're
    doing that you'll realise it depends not only on the frequency but also
    upon the "on time" of the fet. So you can calculate the losses only as
    long as you know the average on time. eg on time = 100% = no gate
    capacitance losses and Rds is dominant. On time = 1% and Rds becomes
    almost irrelevant and the switching losses dominate.
    The Mot rule of Rds losses = to G cap losses works quite well when the
    the average on time is 50%. But it's only a rule of thumb to give you a
    starting point.
  15. D from BC
    D from BC Guest
    Yep...I got my eye on the duty...
    For a given mosfet driver, it seems like this:
    For low duty, then pick low gate charge to reduce Vds transient time.
    For high duty, then pick low Rdson to make an efficient switch.
    I just want to clarify that Mot rule.. (Also..what is Mot? Motorola?)
    Is it...
    Rds pwr = Drain/Source transient switching pwr (or on/off state change
    power)
    Or
    Rds pwr = Drain/Source transient pwr + gate drive power required
    D from BC
  16. Gibbo
    Gibbo Guest
    Yes. Just an abbreviation I used which I think appeared earlier in the
    thread.
    Yes. But the losses increase depending how well the driver operates
    obviously due to drain/gate capacitance. So both are related.
    No that is added in separately.
    I've read some of your posts so I know you're not daft.
    Imagine trying to switch on a mosfet with a 1M source impedance. The
    falling drain voltage would (due to drain/gate cap) hold the gate low
    for [comparatively] ages thus increasing the switching losses (negative
    feedback). Effectivley the gate drive would be slow so the drain voltage
    would fall slowly (thus increasing normal mosfet losses). But you
    already know this.
    I imagine gnome knows all the formulae. Try a new thread with smps in
    the title :)
  17. Terry Given
    Terry Given Guest
    dont forget when comparing FET Rdson to pick some Tj other than 25C.
    different FETs have different Rdson-vs-Tk curves. I always normalise to
    125C and go from there.
    Cheers
    Terry
  18. Gibbo
    Gibbo Guest
    Damned fine point with mosfets.
  19. Guest
    (I'd missed that. Maybe before sending, I should read the stuff :).
    Yes, let spice do the grunt work as your servant, while you figure the
    overall strategies. It's not that the FET usage is complicated, it's
    more that's it can be tantalisingly easy to sit down and spend time
    doing a complete 'carved in Granite' electrical/mechanical FET design
    on paper, building it and then finding real world 'minor' factors
    need taking care of that could only have turned up in some long winded
    tolerancing episode. E.g fitting some readily available value for a
    clock cap' moves the FETs and (say) switching inductors into
    occasional discontinuous cycles.
    john
  20. Gibbo
    Gibbo Guest
    John I'm still trying to work out how to contact you by email. Have you
    done a seacrh on jjdesigns? Quite amusing really.
