G
Gregory L. Hansen
I'm starting to think about building a seismometer, partly because nobody
else seems to believe that Gaithersburg vibrates, and I want to get some
data. I'm pretty naive when it comes to actual availability of stuff
and implementation, so I'm hoping to get some general comments. My
numbers aren't very precise, but good enough for a feasibility check, I
think.
The sensitivity of the human butt is proportional to frequency and has a
limit of around 0.5 mm/s, which at 50 Hz is an amplitude of around 2
micrometers. I don't know for sure that I'm feeling something vertical,
but addressing that is a structural problem, not an electronic problem.
What I allege I am feeling is certainly above 1 Hz, so I've made my
mechanical design goal a boom with weight and spring to have a natural
frequency of around 1/10 Hz. My nominal target then is to measure a 50 Hz
vibration with an amplitude of 2 micrometers, with a range of interest
from 1 Hz to about 100 Hz.
My pickup design is to pair up two horseshoe magnets with a small gap
between them, and a square pickup coil of a few hundred turns dimensioned
and positioned so that the upper segment is between the upper poles and
the lower segment is between the lower poles. I'd thought about a second
coil with the connection and the magnets reversed to reduce noise from
power lines, but those sorts of details are still in the future.
I have little idea what kinds of magnets are available or where to get
them. But I assumed square poles 2 cm on a side with a field strength at
the poles of 1/100 tesla, and presumed that pairing up the magnets would
give a field strength of 2/100 tesla. That's probably a bad assumption
when working with ferromagnetic materials, but I thought it must be good
enough at this stage.
So I get from that a signal of around 0.1 mV. And my Horowitz & Hill is
at work, so I can't compare that with various noises until Monday. But
I don't think 0.1 mV is really in the regime of special low-noise
techniques. The vibrations I allege that I'm feeling have a time
structure of about five seconds on (sometimes multiples of five) and two
seconds off, so I thought it wouldn't be too hard to put a low-pass
filter in there and measure the on/off difference on a voltmeter. If I
carry it around and map out some amplitudes maybe I can figure out where
it's coming from.
think.
it's coming from.
