B
[email protected]
Don't be silly. The client makes up their own mind. The trick is give
them the information they need to make a choice that they are happy
with at the time, and will stay happy with for some time to come.
In your opinion - as if it mattered.
You don't second guess them - you offer them them Stilton and
Roquefort as alternatives to the Kraft Cheddar they learned about the
school canteen.
And 555 experts get job offers from all over the world?
Sure. They are less likely to come back bitching about me not telling
them about a better solution when they find out it exists. But then
again, your customers would not be all that enterprsing to start with.
Well, you would like to think that.
I was perfectly well aware that the OP wanted to select one of 31
channels. It is less clear that they needed - or really wanted - an
eleborate, expensive and complicated decimal display of the channel
number.
Dymo labels look terrible and don't last.
No. But it might well serve the purpose.
Wire-wrapping isn't all that quick - pushing the device into the
printed circuit board doesn't take long, but making all the necessary
connections takes ages.
If the OP actually needed a decimal display - in most cases all that
is necessary is an unambiguous indication of the channel selected and
a hexadecimal number serves the purpose just as well as a decimal
number - it isn't as if the OP wants to do arithmetic with the number
displayed.
One gets satisfied customers by giving them what they want, and
second guessing them by telling them that what they really need and
what you'll provide them with is the Stilton you've selected for
them instead of the Roquefort they really want isn't going to get
you many happy campers.
school canteen.
Or, BTW, many employment offers.
I think the problem isn't one of their being able to determine what
they want, it more like your _not_ being able to determine what they
want and trying to force your decision of what they need down their
throats.
Yes, and you certainly proved that you had no clue that the OP
_wanted_ to be able to switch 31 channels and get a decimal
representation of the hot channel decimally when you unnecessarily
elaborated on that totally useless hexadecimal implementation.
number.
The point isn't that some panel marking methods are cheaper than
others, it's that, basically, your hex "solution" won't yield the
results the OP asked for.
Oh, well...
If I don't go directly from schematic to PCB that's exactly how I do
my prototypes and one-offs. Vector T-44 terminals hot-pressed into
FR-4 perfboard with 0.025" diameter holes on a 0.1" rectangular
grid.
Components are mounted on the forked side of the terminal and the
connections wire-wrapped on the other side of the board. For
high-frequency stuff I use single or double sided copper clad
perfboard and spot-face a 0.1" diameter space around the terminals.
Works great.
You grasp at straws, Sloman.
The client described what he wanted to achieve and presented a
couple of ways he thought would get him where he wanted to be.
Your cockamamie hex rotary switch "solution", LOL, cannot by itself
a decimal display make.
displayed.
