" BUBBA's " . . . no FRILLS (nor fanceeeeee equipment) procedure for the pulling of Q1 and Q2 . . .TO-220 cased power transistors .
HOWTODOITTOIT . . . . .
You need a piece of wood to "whittle" / shave / sand down to slightly less than the gap now existing between the transistors 3 flat terminal BCE leads
and the adjoining PCB surface.
The wood choice could be a large diameter bamboo skewer, chopstick or wooden clothespin half, with its cojoining central coil spring removed.
Prep the thickness dimension of the wooden "tool" and test fit / slip in between the PCB and as close as the bent leads of the power transistor leads as is possible. You have clearance ?
Note that when you then rotate the "stick" / tool, that in one direction of rotation, that it would cause a lifting action of the three terminals, being exerted at about the width of the stick AWAY from the lead bends, THAT would be the WRONG direction, in which to rotate.
The other direction of stick rotation, should cause a lifting / levering action of the 3 leads, being created, right at the bend in their terminals.
Needless to say, that is the correct direction of rotation to be used.
Then you get your 50-75 watt soldering iron with a preference of a conical tip, then get it all tinned up to the extent that it looks like 1/4 inch length of chrome plating being on its very tip end.
THEN you place the wooden tool into position and have the PCB positioned such that the solder joints are being on topside.
Rehearse in your mind, the direction that the wooden tool will then be needed to rotate for the lift up action, being created close to the 3 lead bends.
Now you need to defeat ?X? years of surfactal PbO2 and SnO2 build up on the 3 solder surfaces of the transistors BCE solder blob connections .
Its preferrrable to initially add an application of liquid rosin flux to those blobs and then use rosin cored 60Pb / 40Sn wire solder added to the first solder blob, as the pre heated and tinned iron approachs to heat the junction of the wire solder and blob. As that first blob liquifies, shift to the side for the second one to have wire solder added to it do so also and then the same action for the final third one.
Then you tilt the tip so that all three solder joints can be heated as you move the tip between the initial three joints, where there should just NOW be one big oval blob between the cojoined three .
You may just barely be able to see that condition, as the tensioning on the wooden tool has levered out the transistor, free from the board, just at the minimal degree of heat presence that would free the transistor from its solder blobs.
The REASON for the use of an insulative " tool " was keep the joints free from the heat sapping transfer, that a metal mini screw driver tip or any other metal tool that would thermally conduct away and steal heat from the joints.
That transistor pops free at the MINIMAL heating level needed to be applied to the boards joints.
( I have also saber sawed and ground some one oz FR fiberglass blanks to a 1/4 wide and 2 in length with a 2 in length 1/4 in right angle bend on one end. . . . it looks like a micro carpenters square. )
I carry 3 of these in my tool box, with 4 around, on the work bench. . . . . all still usable after 40+ years of shared use.
Thaaaaaaassssit . . . . .
Need to know the equivalent applicable procedure for pulling that relay ? . . . . as that will be the hardest . . . . Just ask . . . .
73's de Edd . . . . .
My uncle is an incredible self made millionaire. He's the guy who designed the diagram to show you which way to put the batteries in something.
