Z
Zak
Can I buy something in the UK like a conducting "shim" to insert
between batteries and measure current?
Below are some details of what I mean.
I want to measure the current provided by the battery when
something like a radio or walkman is used. The battery might be
anything from AAA to D and could be any type(alkaline, zinc-
carbon, rechargeable, etc).
I once made a "shim" out of a small thin piece of plastic which
was sandwiched by thin metal conductors on either side. A wire
was attached to each conductor and the two wires went a
multimeter.
The idea is to insert this "shim" between the cells. Then run the
appliance and measure the current you settings like volume, fast
forwards, band select, etc.
multimeter.
