SED-Flood control method
Discussion in 'Electronic Design' started by LVMarc, Apr 30, 2007.
  1. LVMarc
    LVMarc Guest
    All sed,
    Place "SED_" in front of your real posts. the random crap generator may
    not create repeatable header??
    Marc
  2. Jim Thompson
    Jim Thompson Guest
    But newbies will be blocked.
    ...Jim Thompson
  3. Joerg
    Joerg Guest
    And the graffiti sprayers will soon "adapt".
  4. Jim Thompson
    Jim Thompson Guest
    Yep. What we need are smarter newsreader software that can read ALL
    headers and discard by routing.
    ...Jim Thompson
  5. Meat Plow
    Meat Plow Guest
    Look into Hamster. Or if your using a Windoze OS earlier than W2K, NFilter.
    #1 Offishul Ruiner of Usenet, March 2007
    #1 Usenet Asshole, March 2007
    #1 Bartlo Pset, March 13-24 2007
    #10 Most hated Usenetizen of all time
    Pierre Salinger Memorial Hook, Line & Sinker, June 2004
    COOSN-266-06-25794
  6. Most floods are mass posted and hence, can be mass deleted as an entire
    block without getting too many valid posts in err.
  7. The client doesn't matter. There is filter software out there that
    will let you filter on ANY aspect of a post's headers, or even on
    content.
    I will let you know what it is after I talk to the dude again.
  8. NFliter is the one I was thinking of. It is very diverse in what it
    allows one to select as criteria to filter on.
    Funny that a Usenet abusive twit like you is giving proper advice.
    How are those multiple personalities working out for you, asshole?
  9. Robert Baer
    Robert Baer Guest
    I have not seen anything that repeated.
    BUT.
    What good will that do?
  10. Robert Baer
    Robert Baer Guest
    ....by routing???
    When all of each posting appears to be ranDUMB?
  11. Robert Baer
    Robert Baer Guest
    Pray tell how - and most especialy how to automate.
  12. Robert Baer
    Robert Baer Guest
    ...."any" aspect????????????
    I think not.
    How the heck is any software going to determine that randumb words
    aer being used>
  13. If you view new posts in chrono form instead of by thread.
    If you think making about ten mouse clics is all that hard, you are
    too lazy for usenet anyway.
    The fact is, even if you pick specific net paths with NFilter or they
    like, the retarded bastards pick a different open port victim each time,
    and your problems start all over again. Best thing is to wait till they
    get done having their fart session, and then block en mass, the CRAP
    they posted en mass. It really is that simple. They are too pussified
    to space out their posts as that would lead to the source being
    traceable at some point, and take up even more of the retard culprit's
    time.
  14. Use your brain. Did you not notice that they were all posted through
    two different ISP's through some unsuspecting victim's open port?
    If YOU can see that pattern, a filter app certainly can.
    All I was saying is that there are filters that CAN filter on content,
    so if you wanted the jihad thread or any thread with "jihad" in it or
    "nazi" in it, etc., you could easily set it up to do so. Most of them
    get set up to filter on header content info.
  15. Jim Thompson
    Jim Thompson Guest
    Then all the crap will start with "SED_" :-(
    ...Jim Thompson
  16. LVMarc
    LVMarc Guest
    wel when your reaer download the header, sort alphabetical andonly keep
    those with SED in the first 3 positions. this is used in other groups
    with some ease in sorting the wheat from the chaff.
    marc
  17. Lamey
    Lamey Guest
    On Tue, 01 May 2007 07:03:35 -0700,
    Wrong again prongioe. Keep trying.
    Usenet lits score:
    GIT-R-DONE!
    #20 Usenet asshole
    #6 Lits Slut
    #11 Most posting trolls/hunters/flonkers 2007
    MassiveProng wrote in:
  18. jasen
    jasen Guest
    I think he means by the Path: header.
    slrn is capable, dunno if it's available for windows though.
    eg:
    Score: =-9999
    Expires: 5/4/2007
    Path: \!news\.suddenlink\.net\!not-for-mail
    <technical>
    slrn uses _xhdr_ to ask for headers that arent provided as part of the _overview_.
    So any message header can be used for filtering, without downloading the
    entire headers or entire message.
    </technical>
    Bye.
    Jasen
  19. James Waldby
    James Waldby Guest
    [snip]
    The X--Complaints-To: field was the same in the few flood
    posts I looked at. Unfortunately, my newsreader (pan)
    doesn't filter on that field.
  20. jasen
    jasen Guest
    slrn will filter (regex filter) on any header line you'd have to
    learn a new user-interface though :(
    Bye.
    Jasen
