Security Alarm
1 Shot 1 Kill
Hello to all,
I have just bought a property that has an security alarm installed, the
previous owner died and I purchased the property from the daughter who lives
5000 miles away and has no idea about the alarm system. I cannot find any
instruction manual whatsoever or any markings on the controller next to the
front door.. I have worked out the 4 pin code to arm/disarm the alarm but
want to edit the settings in programme mode..
Does anyone know how I can find out this code?
N
nick markowitz
Hello to all,
would need to know xactly which system you have there all different
some where theres a box that is the brains for system which should
have a label and model number.
A
alarman
1 said:
Hello to all,
the previous owner died and I purchased the property from the
daughter who lives 5000 miles away and has no idea about the alarm
system. I cannot find any instruction manual whatsoever or any
markings on the controller next to the front door.. I have worked out
the 4 pin code to arm/disarm the alarm but want to edit the settings
in programme mode..
Photo?
Jack
Hello to all,
Would you have a make? A model number?
SOMETHING! .................... to give someone a clue?
There's more than one alarm panel in the world and I left my crystal
ball at work.
G
G. Morgan
1 said:
NNTP-Posting-Host: 92.234.154.43
X-Complaints-To: http://netreport.virginmedia.com
Since you appear to be posting from the UK you may want to ask in:
news://uk.tech.electronic-security
Of course, you'll need to be specific as to the brand/model of the alarm. You
have not provided enough information to get assistance.
D
Doug
1 Shot 1 Kill said:
Hello to all,
lives 5000 miles away and has no idea about the alarm system. I cannot
find any instruction manual whatsoever or any markings on the controller
next to the front door.. I have worked out the 4 pin code to arm/disarm
the alarm but want to edit the settings in programme mode..
I would imagine that the first thing you need to do, is to identify the
control panel and get some documentation on it.
Otherwise the code, if you do find it will allow you do no more than a
little poke & hope programming, not always the best way to figure out how
your security system works.
Doug
1 Shot 1 Kill
Many thanks to all who have responded, unfortunately I can find no markings
anywhere on the control panel but the wires go to a cupboard by the front
door where the gas & electric meter are so maybe the 'brains' to the system
is in there... I will post a picture on Wed when I am back home again.
Also don't know if it has any relevance but just about every room has what
appears to be a 'Panic Button' which also has a key... is the key used to
reset the button if pressed?
Jack
That's probably right but it's not usual to have "holdup" / "panic"
buttons in a residence in every room unless the previous owner
suffered from paranoia. Could be they were used for medical alert too,
but I can't think why they would be key resetable. Maybe previous
owner suffered from short term memory loss ..... also.
Hmmmm. But then he wouldn't remember why he was afraid either.
Need more information.
