Secondary Listed Fuse
Discussion in 'General Electronics Discussion' started by Rajan, May 14, 2014.
  1. Rajan
    Rajan
    3
    May 14, 2014
    can anyone please tell me what "secondary listed fuse" means?
  2. (*steve*)
    25,411
    2,779
    Can you give us some idea of the context?
  3. Harald Kapp
    10,321
    2,239
    Do you mean a fuse on the secondary side of a power supply ("secondary fuse") whre the fuse has an UL listing? Context is important, as Steve noted.
  4. Rajan
    Rajan
    3
    May 14, 2014
    i have an electronics device with a relay output and it says it should be supplied from an isolated transformer using a secondary listed fuse with a max current rating and min VDC rating
  5. (*steve*)
    25,411
    2,779
    Sounds like they suggest you use a transformer with a fuse in the secondary circuit. Helpfully they list the voltage and current rating of that fuse. Do they, perhaps, have a list of possible fuses in the documentation?
  6. Rajan
    Rajan
    3
    May 14, 2014
    yes max 3.3A min 30VDC. "listed fuse" made me wonder if its a special type of fuse
  7. Harald Kapp
    10,321
    2,239
    Listed is very probably short for "UL listed"
