Sears (made by JVC) T.V. no sound.
Discussion in 'Electronic Repair' started by Dani, Jan 15, 2007.
  1. Dani
    Dani Guest
    27" Sears T.V., Model # 57-14367 Chassis # A 53, no sound, otherwise
    T.V. works fine, but you can't access the audio part of the menu at
    all, like speakers on/off, bass, treble, etc. In
    the service menu, it seems to have dissappeared, & other sets with the
    same model have had the adjustments in the customer menu. I can only
    access the balance, & att. for audio. Using
    a JVC remote, I can do everything else in the service menu, except fix
    the sound, & the audio IC has gain. Is there an EEPROM, or Micro
    problem with these units? Thanks, Dani.
  2. Guest
    Sounds like a bad filter or coupling cap on the output.
    or there may be a defective transistor volume control sw in the output
    if one is used
    A Little Bit of Everything..
    http://www.whaatsoever.com
