Sealed lead acid batteries
Discussion in 'Electronic Basics' started by Ted Pillinger, Mar 25, 2008.
  1. Hi
    What is the fastest rate of discharge advisable for a sla battery?
    Is the terminal voltage a good indication of the condition of a charged
    battery?
    Ted
  2. Phil Allison
    Phil Allison Guest
    "Ted Pillinger"
    ** Just a tad less than that required to blow the internal fuse.
    ** No.
    ....... Phil
  3. Chuck
    Chuck Guest
    If by condition you mean state of charge, then terminal voltage is
    about the only indicator available. Terminal voltage doesn't vary much
    between 50% and 100% charge, but it provides a rough indication. If
    you try to measure terminal voltage right after charging, you are
    likely to see an elevated, incorrect reading.
    If by condition you mean battery capacity, terminal voltage by itself
    will tell you nothing.
    Do a search on battery faq and you'll find more info.
    Chuck
  4. Bob
    Bob Guest
    I'd say the rate advised by the manufacturer in the data sheet
    Do SLA batterys usually have an internal fuse?
    I'v never seen any mention of one in manufacturer's literature.
    I have seen the aftermath of people short circuiting large gelcell/AGM
    batterys and heard storys of other incidents. This is almost allways
    due to people using an uninsulated spanner and rotating it so it
    touchs another battery terminal or the chassis, although ocasionally
    people put a link lead on the wrong terminal.
    I'v never heard of a battery fusing, if the short is cleared after a
    few
    seconds the batterys works afterwards.
    In my experiance the off-load off-charge voltage of a
    charged SLA battery only gives a meaningfull indication
    when the battery is near the end of it's life.
    When the battery has only a fraction of it's capacity left,
    in the region 10% of the original AH rating,
    the voltage drops quickly off charge,
    eg if a nominal 12volt battery is at 12.5V instead of 13.5 straight
    after being taken off charge it probably has significantly reduced
    capacity and will probably be useless within a year.
  5. Phil Allison
    Phil Allison Guest
    "Bob"
    "Phil Allison"
    ** Many of them do.
    If you short or overload the battery - the battery goes open.
    It's a simple safety feature against explosion.
    ....... Phil
