SDRAM
R
RobertP
Does someone know if there is a way to force SDRAM chip data outputs
into High-Z state asynchronously? Is asserting CS inactive sufficient?
S
Stefan Heinzmann
No (unless I've misinterpreted the JEDEC standard). The only
asynchronous input is CKE, and deasserting CKE alone won't do what you
want. You may want to have a look at the relevant standards at www.jedec.org
A
Arie de Muynck
No.
We had problems when a CPU watchdog fired in the middle of a burst
transfer - the DRAM outputs stayed active and the Boot Flash could not be
read anymore.
The problem was solved with some glue logic in a CPLD that gave off an abort
cycle to the SDRAM when the reset did tri-state the micro's outputs.
Regards,
Arie de Muynck
