SD Card Reader repair
Discussion in 'Troubleshooting and Repair' started by khankll, Jul 30, 2013.
  1. khankll
    khankll
    110
    Feb 6, 2011
    hi
    i have more then a dozen sd card readers .. al made by siyotem ..
    it works ok and after left un unsed for few weeks /months .. it wont work ..
    i have tried cleaning the contacts . but to no luck . tried soldering the contacts .. no luck .
    could it be that the ics are programed to go broke after some specific number of uses ?
    or could there be any part on it that could go broke.. how to test and repair it..
    no physical damge has happened to it . they would be working ok .. before being stored in closet in closed plastic box where there is no moisture etc.
    on some card readers the led on card reader would glow and windows would detect them in device manager and the corresponding drive will be shown in my computer but it is shown as 0 bytes and cannot be opened/explored ..tried in linux as well.. on others card readers (they also lack any crystal etc o their pcb ..) they dont even show up in device manager and neither their led comes up ..
    i am suspecting the crystal to be the issue .. is there any way one could test it ? some realy cheap dirty method .. ?
    i am posting it in repair section to get some clue regarding repair not an advice to buy a new one as these are cheap .. oh btw i do have a new one .. whenever it is not working i buy new one .. but this time i want to repair those dead as well ..
    this is the card circuit board
    http://www.instructables.com/answers/How-to-fix-card-reader/
  2. (*steve*)
    25,497
    2,838
    I have had a few SD card readers that have failed almost exactly as you describe.
    I put it down to either damage by static or a 3.3V device being run at 5V.
    Either way I just replaced them with something more reliable.
    If you have access to an oscilloscope then you may be able to probe the crystal to see if its oscillating. I'd use a x10 probe at a minimum.
  3. davenn
    davenn Moderator
    13,837
    1,952
    going by the responses on that blog, it sounds as tho that particular reader is useless
    and not worth trying to salvage
    as Steve said, get a better quality one
  4. khankll
    khankll
    110
    Feb 6, 2011
    yaa its cheapo .. but i have a huge ewaste lying .. just wanted to give it a repair shot ..
    if i ever succeed in repairing it .. or most importantly in findng the reason for its sudden damage .. i will update here .
