Screwdrivers?
Discussion in 'General Electronics Discussion' started by Pexy, Aug 26, 2018.
  1. Pexy
    Pexy
    142
    3
    Feb 21, 2016
    Greetings!
    I'm slowly upgrading my tools and equipment regarding my workbench and i think it's time to upgrade my screwdrivers.
    My current set consists of a few different screwdrivers I found laying around the house.
    Mostly cheap and with semi stripped heads.
    Now I'm thinking about getting an insulated set. Is it worth it or will the insulation only interfere.
    What kind do you have/prefer? Any recommendations for a decent quality set or brand for 20-25$.
  2. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Insulated screwdrivers are generally used by 'electricians' although they are sometimes useful for working on high voltages in hobby work. Unless you have the intention to work with domestic electrical systems or high voltages as may be found in valve equipment then you'd probably not find them used very much but, as with all tools, if you haven't got one, you'll eventually find you need one.....
    Pexy likes this.
  3. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    Screwdrivers can be reground and soft ones may need to be ground often.
    The insulation will not interfere with anything.
    You could get a set of driver bits for various screws including cross bits and Phillips.
    A set of watchmaker screwdrivers will often come in handy.
    I use a 'magic' (neon) screwdriver to check live terminals.
    The first scewdriver I bought 60 years ago was soft rubbish but I still insist on usong it, including taking lids off cans and stirring paint. Modern tools are all much better and are often Cr-V steel.
    Pexy likes this.
  4. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    I wouldn't recommend a 'neon' screwdriver for testing live terminals. Use a proper non-contact detector 'pen' - cheap and very much safer.
    You will gather a 'massive' collection of screwdrivers over the years - if I could be bothered to count them I reckon I'd get to over 40 quite easily in my collection. Of those I probably use only three or four regularly.
    Pexy likes this.
  5. Pexy
    Pexy
    142
    3
    Feb 21, 2016
    Ok then i need to check how to grind them so maybe i can refurbish my current set.
    I have a set of security and fine pointed bits but i only use it when dealing with small things
    because the biggest one is ph0
  6. Pexy
    Pexy
    142
    3
    Feb 21, 2016
    Agree with you on the non-contact tester and if you pair it with a multimeter you pretty much can't go wrong.
    It would be great to have a collection of screwdrivers that you collect over the years but my "years" have just started :D
  7. Ian
    Ian Administrator
    1,487
    435
    Aug 23, 2006
    I really like Wera screwdrivers - they are a bit more expensive than normal ones, but they are really good quality (I had one break and they replaced it a year later without question).
    I've got a set of the normal green/black ones for every day use, plus a small selection of VDE rated ones for high voltage stuff.
    My favourite screwdriver is this Wera ratchet one, as the ratchet mechanism is much finer than most and a small selection of common bits is integrated in to the popup mechanism. Having replaceable bits is really handy, as they can be replaced cheaply and save a lot of space. It's a little more than your budget, but Amazon do sometimes have good offers.
    dave9 and Pexy like this.
  8. Pexy
    Pexy
    142
    3
    Feb 21, 2016
    Yeah I've seen people use Wera screwdrivers. I'll sniff around and see if i can find a set that I would like and can afford. Also the ratcheting screwdrivers look like a realy good thing.
Similar Threads
Loading...
