Categories
Platforms
Content
1.2V from gate to which point in the circuit?We are giving 1.2volt to each gate of each scr for triggering at respected time.
An scr requires the trigger voltage to be applied between gate and cathode.
The normal method to trigger a SCR with a floating cathode is to use a pulse transformer with the secondary connected to cathode and gate.
You must get the polarity right, positive gate to trigger on.
A triac will switch the supply in both directions with a trigger in either direction.
Where is ground in your circuit? It is not shown in your pdf. Also you cannot have the sources of both scrs connected to the same ground, as the scrs are antiparallel.Sir we are giving positive 1.2V to the gates with respect to ground
You could also use an optocoupler to provide current to the gate (from the anode).
Triacs are often triggered in a similar way.
edit: beware that this won't allow for triggering right from the zero crossover and you need to be careful about maximum gate current.
This is the third time I tell you that the trigger voltage has to be applied between gate and source of the scr. Do you know how an scr works?
Since the sources of boths scrs are on opposite sides, duke's tip to use a transformer is a good one. Here it is shown how to do it.
Alternatively you could use just one single scr and put it on the DC-side of a bridge rectifier. Then you have only one gate to control. Put the load and the voltage source on the AC side of the bridge. Thus the load will see AC but the scr wil have to switch ony DC. But there still remains the problem of potential isolation between the driving circuit and the high voltage circuit. Therefore the transformer is still the better solution.
You repeat talking about a connection to gnd, but your circuit diagram (PDF) is incomplete. It doesn't show where gnd is and thus your textual explanations are of little help.
We need to see the complete control circuit. At least the part that contains the trigger voltage to the gates and that ominous gnd you keep talking about without showing us.
Also, I repeat (the umpteenth time), the cathodes (K) of the two anti-parallel scrs are connected to different potential. Since you have to apply the trigger impulse between gate and cathode, obviously this cannot be achieved by connecting the trigger voltage between gate and gnd. Because that would mean that gnd is on both sides of the two scrs and thus would create a short circuit.
So at best gnd can be connected to one side of the scr which in turn makes it clear that the trigger impulse can work only for that scr, where gnd=cathode. On the other scr gnd=anode and therefore this will not be triggered correctly.
The attachment is missing.
