P
Paul E. Schoen
I have been working on a high current test set which uses SCR Solid State
Relays to drive the primary of a transformer with 480 VAC mains power. There
is a contactor which closes to apply power to the SSR, and then at a later
time it is energized at the peak voltage point to reduce DC offset into the
inductive load. The output of the transformer is about 2 volts and is
capable of supplying 20,000 amperes or more into a low impedance load
(circuit breaker), or a shunt for the purposes of calibration.
The problem has been that, sometimes, the SCR will conduct for a half-cycle
or so when the contactor closes. We have tried all sorts of snubbers across
the SCRs and also across the primary of the transformer, with some success,
but it still occasionally triggers, which sometimes causes a very high
inrush and it has blown 100 ampere LPS fuses.
I made an LTSpice simulation that is roughly the same as the actual circuit,
and it mostly performs as expected. But the SCR triggers on for 1/4 cycle
when the contactor is closed at the voltage peak (but also at other phase
angles). I have tried various snubbers and even series inductance to reduce
the dV/dt which seems to be triggering the SCRs. But nothing worked.
However, when I put a resistance of less than about 1 MegOhm across the
contactor, only a very small spike occurs at turn-on. I will be doing work
on the actual unit tomorrow, but I'd like to understand what may be going on
before then. Any ideas will be appreciated.
Paul
Here is the ASCII file:
Version 4
SHEET 1 1756 680
WIRE 0 -96 -48 -96
WIRE 96 -96 80 -96
WIRE 64 -16 -112 -16
WIRE 96 -16 96 -96
WIRE 400 -16 96 -16
WIRE 560 -16 544 -16
WIRE 704 -16 560 -16
WIRE 16 16 -208 16
WIRE 64 16 64 -16
WIRE 288 16 272 16
WIRE 416 16 368 16
WIRE -48 64 -48 -96
WIRE -16 64 -48 64
WIRE 0 64 -16 64
WIRE 96 64 96 -16
WIRE 96 64 80 64
WIRE 128 64 96 64
WIRE 256 64 128 64
WIRE 272 64 272 16
WIRE 272 64 256 64
WIRE 416 64 272 64
WIRE 512 64 480 64
WIRE 560 64 560 -16
WIRE 560 64 512 64
WIRE 704 64 704 -16
WIRE 960 64 832 64
WIRE 704 112 704 64
WIRE 832 112 832 64
WIRE 960 112 960 64
WIRE -208 128 -208 16
WIRE -48 160 -48 64
WIRE 256 160 256 64
WIRE 288 160 256 160
WIRE 512 160 512 64
WIRE 512 160 352 160
WIRE 128 176 128 128
WIRE 384 208 352 208
WIRE 512 208 512 160
WIRE 512 208 464 208
WIRE -208 240 -208 208
WIRE -112 240 -112 -16
WIRE -112 240 -208 240
WIRE -48 256 -48 240
WIRE 128 256 -48 256
WIRE 704 256 704 192
WIRE 704 256 128 256
WIRE 832 256 832 192
WIRE 832 256 704 256
WIRE 960 256 960 192
WIRE 960 256 832 256
WIRE -48 288 -48 256
FLAG -48 288 0
FLAG -16 64 Vin
FLAG -208 240 0
FLAG 704 64 Vrly
SYMBOL res 112 160 R0
SYMATTR InstName R1
SYMATTR Value 1
SYMBOL cap 112 64 R0
SYMATTR InstName C1
SYMATTR Value 6µ
SYMBOL voltage -48 144 R0
WINDOW 3 103 175 Left 0
WINDOW 123 0 0 Left 0
WINDOW 39 22 174 Left 0
WINDOW 0 -45 9 Left 0
SYMATTR Value SINE(0 720 60 0 0 0 240)
SYMATTR SpiceLine Rser=.1
SYMATTR InstName V1
SYMBOL sw 96 64 R90
WINDOW 3 49 -5 VRight 0
WINDOW 0 24 92 VRight 0
SYMATTR Value MySwitch
SYMATTR InstName S1
SYMBOL ind2 688 96 R0
WINDOW 3 21 114 Left 0
SYMATTR Value 500m
SYMATTR InstName L1
SYMATTR SpiceLine Rser=100u Rpar=1Meg
SYMATTR Type ind
SYMBOL voltage -208 112 R0
WINDOW 3 -219 162 Left 0
WINDOW 39 0 0 Left 0
SYMATTR Value PWL(0 0 .054167 0 .054168 5 .55 5 .551 0 .9 0 .91 5 1.6 5 1.61
0 1.90 0 1.91 5 2.85 5 2.851 0 3 0)
SYMATTR InstName V2
SYMBOL Misc\\SCR 480 48 R90
SYMATTR InstName U1
SYMBOL Misc\\SCR 288 176 R270
SYMATTR InstName U2
SYMBOL res 560 -32 R90
WINDOW 0 0 56 VBottom 0
WINDOW 3 32 56 VTop 0
SYMATTR InstName R2
SYMATTR Value 20
SYMBOL cap 464 -32 R90
WINDOW 0 0 32 VBottom 0
WINDOW 3 32 32 VTop 0
SYMATTR InstName C2
SYMATTR Value .47µ
SYMBOL ind2 848 96 M0
SYMATTR InstName L2
SYMATTR Value 50µ
SYMATTR SpiceLine Rser=50u Rpar=1Meg
SYMATTR Type ind
SYMBOL res 944 96 R0
SYMATTR InstName R3
SYMATTR Value 100µ
SYMBOL res 96 -112 R90
SYMATTR InstName R4
SYMATTR Value 250k
SYMBOL voltage 368 208 R270
WINDOW 3 291 -216 VRight 0
WINDOW 39 24 -12 Left 0
SYMATTR Value PWL(0 0 .1041667 0 .1041700 5 .5041667 5 .50417 0 1.00 0 1.001
5 1.50 5 1.501 0 2.004167 0 2.004168 5 2.5 5 2.75 5 2.7501 0 3 0)
SYMATTR InstName V3
SYMBOL voltage 384 16 M270
WINDOW 3 128 -1014 VRight 0
SYMATTR InstName V4
TEXT -408 200 Left 0 !.tran 3 startup
TEXT -392 344 Left 0 !.model MySwitch SW(Ron=.01 Roff=100Meg Vt=2 Vh=-.5
Lser=10n Vser=0)
TEXT -24 160 Left 0 !.inc SCR.SUB
TEXT 720 16 Left 0 !K1 L1 L2 1
The SCR model (SCR.sub) modified from
http://pages.suddenlink.net/wa5bdu/ltguide.pdf is:
* SCR:
* Extracted from PONT_DIPH.CIR file from EDN website.
* I renamed that file as SCR_CKT.CIR
* Anode
* | Cathode
* | | Trigger
..subckt SCR 1 3 2
* (I had to change the above line to match the pins of the SCR symbol)
* Models used by the SCR model:
..model STH VSwitch (ROn=0.1,VOff=0.5)
..model DLG D (Rs =25m)
* We assume that the SCR in the on-state is equivalent to 0.1 ohm:
SSCR 1 4 5 0 STH
VSCR 4 2 0V
* Trigger to cathode impedance is a 1k ohm resistance - for simplification:
RTrig 2 3 1k
* The following circuit locks in the on-state when a 1mA current flows
* through the gate to the cathode with a positive anode to cathode voltage.
* This circuit locks in the off-state when the current through ths SCR tends
* to become negative:
VPlus 6 0 2V
SiTrig 6 5 3 2 STH
CState 5 0 1uF IC=0
DLogic 5 8 DLG
HCur 8 0 poly(1) VSCR 1 10000
* The potential of node 5 reflects the state of the SCR. It is less than 1V
* for the off-state and between 1V and 2V in the on-state.
..ends
Paul
Version 4
SHEET 1 1756 680
WIRE 0 -96 -48 -96
WIRE 96 -96 80 -96
WIRE 96 -16 96 -96
WIRE 400 -16 96 -16
WIRE 16 16 -208 16
WIRE 64 16 64 -16
WIRE 288 16 272 16
WIRE 416 16 368 16
WIRE -48 64 -48 -96
WIRE -16 64 -48 64
WIRE 0 64 -16 64
WIRE 96 64 96 -16
WIRE 96 64 80 64
WIRE 128 64 96 64
WIRE 256 64 128 64
WIRE 272 64 272 16
WIRE 272 64 256 64
WIRE 416 64 272 64
WIRE 512 64 480 64
WIRE 560 64 560 -16
WIRE 560 64 512 64
WIRE 704 64 704 -16
WIRE 960 64 832 64
WIRE 704 112 704 64
WIRE 832 112 832 64
WIRE 960 112 960 64
WIRE -48 160 -48 64
WIRE 256 160 256 64
WIRE 512 160 512 64
FLAG -48 288 0
FLAG -16 64 Vin
FLAG -208 240 0
FLAG 704 64 Vrly
SYMATTR InstName R1
SYMATTR Value 1
SYMATTR InstName C1
SYMATTR Value 6µ
SYMATTR InstName V1
SYMBOL sw 96 64 R90
SYMATTR InstName S1
SYMATTR Value 500m
SYMATTR InstName L1
SYMATTR Type ind
SYMATTR InstName V2
SYMATTR InstName U1
SYMATTR InstName U2
SYMATTR InstName R2
SYMATTR Value 20
SYMATTR InstName C2
SYMATTR Value .47µ
SYMATTR InstName L2
SYMATTR Value 50µ
SYMATTR Type ind
SYMATTR InstName R3
SYMATTR Value 100µ
SYMATTR InstName R4
SYMATTR Value 250k
SYMATTR InstName V3
SYMATTR InstName V4
Lser=10n Vser=0)
* SCR:
* Anode
* | Cathode
* | | Trigger
..subckt SCR 1 3 2
SSCR 1 4 5 0 STH
VSCR 4 2 0V
RTrig 2 3 1k
VPlus 6 0 2V
SiTrig 6 5 3 2 STH
CState 5 0 1uF IC=0
DLogic 5 8 DLG
..ends
