B
[email protected]
Hi
I have Schneider DVDR HDD 160 and when I record from any source to
hard disk or dvd in both cases the recording process freeze after less
than minute. The produced file when played also freeze after less than
minute.
Also the recorded sound is not playing while on the unit, but I tried
it on my pc after finalizing the DVD the sound is there but also the
file is stopped at the same place and the speed of file is not normal.
The time in witch the recorder file stops is different from each case
but it is constant for each file.
I tried from AV1 and AV2, and on Hard disk and DVD, also I changed all
the configuration but still same problem.
I even tried to record for 16 minutes but the resulted file stuck on
the 29th second.
any one can help?
Thanks un advance
minute.
the 29th second.
any one can help?
Thanks un advance
