schmitt trigger
Discussion in 'General Electronics Discussion' started by steven4, Nov 23, 2014.
  1. steven4
    steven4
    Nov 23, 2014
    I was building a Schmitt trigger circuit as depicted by one of my electronics books but unfortunately I found my op-amp burning. I am worried about the voltages that um supplying my op-amp(15V and -15) with.
  2. Anon_LG
    Anon_LG
    453
    117
    Jun 24, 2014
    Check the op-amps datasheet, check whether you are exceeding any of the stated maximum values. Also you should show your schematic, this would allow a solution to be found.
  3. hevans1944
    hevans1944 Hop - AC8NS
    4,562
    2,135
    Jun 21, 2012
    Welcome to the Electronics Point forums!
    Please hand-sketch your op-amp circuit, take a picture of your sketch, and upload it here. Identify all the components by value and identitfy the part number of your op-amp. It helps if you assign IDs to each part, such as R1, R2, C1, etc. Active components (such as op-amps and logic) are usually identified as U1, U2, etc. If you do this, forum members will be more easily able to help you.
  4. steven4
    steven4
    Nov 23, 2014
    U1=TL061
  5. Bluejets
    Bluejets
    4,505
    958
    Oct 5, 2014
    I think you should read again what Hevans1944 said above.:rolleyes:
  6. KrisBlueNZ
    8,393
    1,270
    Nov 28, 2011
    Your circuit in post #4, with a TL061, should work fine. Double-check your construction against the pinout in the TL061 data sheet, and make sure you've numbered the pins like this.
