Hi
The challenge is on!
And trip the RCD which stops the pump.
What RCD? Plenty of places don't have one. For this experiment its a
location with no RCD, of any kind.
OK you could use an isolating transformer to stop that, (with extreme
care)
lol, I dont think it would be extreme care trying anything like this
but when the seal between the motor and pump vanes leak (they are not
designed for water)
you get water in the motor electrics, electrolysis, and corrosion will
eventually stop the motor
ah no, you misunderstand, its worse than that. In cylinder vacs all
the air pumped by the impellor goes straight thru the motor to cool
it. Not around it, thru it. That's how they use such small high power
motors. So if one is used for pumping, the water goes right thru the
motor mechanics and electrics from minute one.
if the huge increase in power caused by the presumably low conductivity tap
or worse still dirty water doesn't.
It could last a few minutes if you bypass the RCD. (MTBF 0.1 hrs my
estimate)
We got a 500 watt motor on a 30A fuse, 240v ring main. There is the
question of just how much power would flow thru the water, I don't
know. I spose if we dip most of the mains lead in the water we could
at least cool that too. After all its only 2A rated.
No, how silly of you, you can't pump water thru a motor.
Hehe, how much you want to bet? I say it can be done. And I'm wililng
to post practical results.
NT, you've given us a bit of an underspecified problem - thus the ensuing
confusion.
When you say "possible," what do you mean? Do you mean "will it move any
water at all," or do you mean "is this a reliable way to move water," or "is
this a reliable and efficient way to move water," or ...?
I simply mean is it possible - not is it reliable, safe and sensible,
just possible. And not for 3 seconds, but possible to empty the whole
1000 gallon tank. That's about 4.5 tonnes of rainwater. So I expect
it'll need to run for more than 0.1 hours.
And, when you say
"clean water," do you mean "clean and relatively ion-free water" or do you
mean "water with no large suspended objects such as seaweed and/or rubber
duckies"?
A big tank of rain water sitting next to a house. So, barely clean, no
ducks anyway. Certainly not ion free.
Of course you can pump clean water with a cylindrical vacuum cleaner, if you
use it as a piston within some larger cylinder with appropriate valves. But
I assume that's not what you mean.
Hehe. What I mean is by plugging it in the mains and sticking the
nozzle in the water. The really stupid way.
Well no-one's convinced me I can't do it yet
In case anyone's tempted, NEVER try this dangerous idea at home. Its
really stupid.
Regards, NT
