Scanner which can read text?
Discussion in 'Electronic Design' started by jis, Sep 13, 2007.
  1. jis
    jis Guest
    I have got a label which has got bar codes and text informations I
    can read the bar codes thru bar code scanner. But I want to read the
    text informations in the label too. Can any one suggest not so costly
    method of doing this. I know we can use image scanners.
    Any crazy ideas ..pls share.
    I am trying to implement a label verification equipment.
    Cheers,
    Jis
  2. My Canon flatbed scanner came with text reading software.
    I guess you could parse the generated tiff for barcodes too.
    Bit slow though.
    And only works for flat labels.
  3. JeffM
    JeffM Guest
    That's the first bit.
    Here's the 2nd:
    http://www.google.com/search?q=Optical.Character.Recognition.software&num=100
    If you do it right, you get the proper tool to start with:
    http://www.google.com/search?q=cach...herals/Scanners/Portable+Cool+barcode+*-*-OCR
  4. EdV
    EdV Guest
    http://www.yourmobiledesk.com/produ...5059&catID=82&subcatID=na&sscatID=na&mfrID=na
