E
Eric Kotz
Hello all,
I picked up a Ricoh SLP-416c Color Laser Printer at a hamfest today for
$30. It works...sort of. Basically, best I can tell, the unit has 4
toner cartridges stacked on on top of each other and a green
photosensitive imaging "ribbon" This in turn transfers each colors'
toner onto a red-brown, "holding" drum, and when all 4 colors are on
this holding drum, the paper passes between this drum and the corona
wire, into the fuser, and out of the printer.
Now...when I got this printer, the fuser oil had spilled inside it.
Luckily, it mostly concentrated in a few places - in particular this red
drum. I've taken apart the printer and cleaned it the best I could and
it seems OK now, but I have one problem (which may or may not have
existed prior to the oil spilling)
About 50% of the toner appears to be sticking to this drum rather than
fusing to the paper. This results in the image being pale and spotty on
the paper (almost looks like the toner cartridges are running out, but
this is not the case) I believe the imaging ribbon is in good condition
as the image "builds up" on this drum solidly.
Can anyone tell me what this drum is? I'm wondering if it still has an
oil residue on it and that is why the toner is sticking to it.
Alternatively, perhaps the HV for the corona wire is not high enough for
some reason? What can this red drum safely be cleaned with?
Eric Kotz
[email protected]
Eric Kotz
[email protected]
